Running Solaris NRPE Agent on Solaris 11
gshah2006
Post by gshah2006 »
Having an issue running the "fullinstall" script on Solaris 11, even after making the work around changes provided by Nagios Documentation on the link below.
root@solaris11:/tmp/solaris-nrpe-agent# ./fullinstall
Nagios XI Solaris Agent Installer
This script will do a complete install of the Nagios XI
Solaris agent by executing all necessary sub-scripts.
IMPORTANT: This script should only be used on a Solaris
           system.  Do NOT use this on a system running
               any other operating system.
Do you want to continue? [Y/n] Y
Proceeding with installation...
Current step is 0-prereqs
Running './0-prereqs'...
top found
RESULT=0
0-prereqs appears to have already completed successfully. Moving on to the next step.
Current step is 1-usersgroups
Running './1-usersgroups'...
RESULT=0
1-usersgroups appears to have already completed successfully. Moving on to the next step.
Current step is 2-plugins
Running './2-plugins'...
Attempting to install NGOSplugin from nagios-plugins-1.4.16-sol10-sparc-local
ld.so.1: pkgadd: fatal: libssl.so.1.0.0: open failed: No such file or directory
ld.so.1: pkgadd: fatal: relocation error: file /usr/lib/libpkg.so.1: symbol SSL_load_error_strings: referenced symbol not found
./2-plugins: line 111: 3143: Killed
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './2-plugins'
Instructions on Installing the Solaris Agent, on Solaris 11: https://assets.nagios.com/downloads/nag ... _Agent.pdf
Reason: Please use [code][/code] tags around long output
bolson
Re: Running Solaris NRPE Agent on Solaris 11
Post by bolson »
Hello Gshaw2006,
It would appear that the SSL libraries are not installed on your Solaris box. Please install openssl using pkgadd and run the ./fullinstall script again. Thank you!
