Hi Team,
Thanks in advance.
1. how to fetch JMX counters present on windows machine using nagios xi. ?
I have Windows machine with my application and i want to fetch the JMX counter of my application using nagios. how can i do that ?
I observed the nagios provided the following documentation to fetch JMX on linux machine with agent :https://assets.nagios.com/downloads/nag ... 1530157277.
2. Can we fatch JMX counter without agent ?
Re: how to fetch JMX counters present on windows machine
The document you referenced covers the basics.kasim wrote:1. how to fetch JMX counters present on windows machine using nagios xi. ?
The only "Linux" requirement in that document is to use NRPE to execute the check_jmx plugin. There's nothing stopping you from re-writing the check_jmx plugin to work on Windows and loading it into NCPA or NSClient++. It's pretty simple:
#!/bin/sh
# Nagios plugin to monitor Java JMX (http://java.sun.com/jmx)attributes.
RDIR=`dirname $0`
$JAVA_HOME/bin/java -jar $RDIR/jmxquery.jar $@You could alter the app's JMX configuration to be available to a range of IPs, or all IPs, or just your Nagios machine. This can all be done via the runtime's system properties.kasim wrote:2. Can we fatch JMX counter without agent ?
Once the JMX connection is available to your Nagios machine, you could simple execute check_jmx, as described in the documentation, from the Nagios machine replacing "localhost" with the remote machine's address.
Thanks for the assist, @mcapra! OP, please let us know if you need further assistance.
