[Solved] 5.5.0 > 5.5.1 - Upgrade reporting as failed
JGCG
Post by JGCG »
I've just upgraded to 5.5.1 from 5.5.0.
I recieved the following message about the upgrade failing:
"The update did not complete successfully. Please try updating manually".
But, the log shows "Nagios XI Upgrade Complete!" and the update page shows we're on 5.5.1:
Latest Available Version: 5.5.1
Installed Version: 5.5.1
Did it fail? What action do we need to take.
Log attached.
Re: 5.5.0 > 5.5.1 - Upgrade reporting as failed
Looking at the log this succeeded. you can simply click the "Go Back" button up the upgrade page.
JGCG
Post by JGCG »
Thanks Scott.
jomann
Development Lead
Re: [Solved] 5.5.0 > 5.5.1 - Upgrade reporting as failed
Post by jomann »
Great, closing this
