Nagios 5.5.1 backups going to wrong place
Since the update to 5.5.1 my backups are appearing locally and not on my ftp server.
I have been through the options and they are definitely set to go to the ftp server with local backups disabled.
Re: Nagios 5.5.1 backups going to wrong place
Are you having any issues when testing the connection/upload under the Scheduled Backups page (the FTP tab)? Can you show us a screenshot of this page?
Run the following commands, and show the output:
# On the Nagios XI server:
# On the FTP server:
On the Nagios XI server, open the /usr/local/nagiosxi/html/includes/constants.inc.php file, and set the scheduled backup log level to "debug":
Go to Admin > Scheduled Backups > FTP tab, set the Schedule For time to a few minutes in the future, and click on Update Settings. Immediately start a running tail on the cmdsubsys.log, and watch the output. When the backup is complete (or "hung up"), stop the tail (ctrl+c), and copy/paste the output to the forum. Please make sure you've waited long enough for the output to show up in the tail command.
Also, post the entire /usr/local/nagiosxi/var/components/scheduledbackups.log file.
Rerun the first two commands, showing the content of the backup directories on the Nagios XI and FTP server once more, and show the output. Thank you!
ls -la /store/backups/nagiosxi/Code: Select all
ls -la </path/to/the/backup/directory>Code: Select all
// Scheduled backups constants
// 0 - Debug, 1 - Info, 2 - Warning, 3 - Error
define('SB_LOGLEVEL', 0);Code: Select all
tail -f /usr/local/nagiosxi/var/cmdsubsys.logRerun the first two commands, showing the content of the backup directories on the Nagios XI and FTP server once more, and show the output. Thank you!
I have deleted a couple of the .tgz files to save space, however, here is /store/backups/nagios
Tail as requested
Contents of /usr/local/nagiosxi/var/cmdsubsys.log
[martinp@localhost ~]$ ls -la /store/backups/nagiosxi/
total 2852476
drwxr-xr-x 3 nagios nagios 4096 Jul 19 11:51 .
drwxr-xr-x. 6 root root 4096 Jul 16 09:47 ..
-rw-r--r-- 1 nagios nagios 1403184383 Jul 16 09:46 autoupgrade_backup.1531730515.tar.gz
drwxr-xr-x 2 nagios nagios 4096 Aug 22 2017 nagiosxi.1503413402
-rw-r--r-- 1 nagios nagios 1517688141 Jul 18 15:55 nagiosxi.1531925401.tar.gz
[martinp@localhost ~]$Code: Select all
[root@localhost martinp]# tail -f /usr/local/nagiosxi/var/cmdsubsys.log
CMDLINE=sudo /usr/local/nagiosxi/scripts/backup_xi.sh -n nagiosxi.1532008202
No entry for terminal type "unknown";
using dumb terminal settings.
Stopping nagios: .done.
Starting nagios: done.
Backing up NagiosQL...
tar: Removing leading `/' from member names
Backing up Nagios Core...
PHP Warning: Invalid argument supplied for foreach() in /usr/local/nagiosxi/html/includes/components/nagiosim/nagiosim.inc.php on line 491
....................tar: /usr/local/nagios/share/perfdata/cmc1-salesview.olmdemo.co.uk/ContractManagement_Login_Page_URL_Content.rrd: file changed as we read it
tar: /usr/local/nagios/share/perfdata/cmc1-salesview.olmdemo.co.uk: file changed as we read it
...............tar: /usr/local/nagios/share/perfdata/DPA_VM2_Shropshire: file changed as we read it
.......................tar: /usr/local/nagios/var/ndo.sock: socket ignored
..PHP Warning: Invalid argument supplied for foreach() in /usr/local/nagiosxi/html/includes/components/nagiosim/nagiosim.inc.php on line 491
PROCESSED 0 COMMANDS
..............................tar: /usr/local/nagios/var/rw/nagios.qh: socket ignored
tar: /usr/local/nagios/var: file changed as we read it
..Copying ramdisk configuration...
Backing up Nagios XI...
...........tar: /usr/local/nagiosxi/var: file changed as we read it
........Backing up MRTG...
...Backing up the SNMP trap interface configuration files...
Backing up NRDP...
...Backing up Nagvis...
Backing up MySQL databases...
...................Backing up PostgresQL databases...
.Backing up cronjobs for Apache...
Backing up logrotate config files...
Backing up Apache config files...
Compressing backup...
.............PHP Warning: Invalid argument supplied for foreach() in /usr/local/nagiosxi/html/includes/components/nagiosim/nagiosim.inc.php on line 491
...........................................................PHP Warning: Invalid argument supplied for foreach() in /usr/local/nagiosxi/html/includes/components/nagiosim/nagiosim.inc.php on line 491
BACKUP COMPLETE
===============Code: Select all
Warning: Duplicate definition found for service 'Check Memory Array - chassis-2/blade-1' on host 'slgpiucs01_blade_2_1_SLGPIESX08' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 265)
Warning: Duplicate definition found for service 'Check Memory Array - chassis-1/blade-5' on host 'slgpiucs01_blade_1_5_SLGPIESX09' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 256)
Warning: Duplicate definition found for service 'Check Memory Array - chassis-1/blade-4' on host 'slgpiucs01_blade_1_4_SLGPIESX01' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 247)
Warning: Duplicate definition found for service 'Check Memory Array - chassis-1/blade-3' on host 'slgpiucs01_blade_1_3_SLGPIESX03' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 238)
Warning: Duplicate definition found for service 'Check Memory Array - chassis-1/blade-2' on host 'slgpiucs01_blade_1_2_SLGPIESX05' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 229)
Warning: Duplicate definition found for service 'Check Memory Array - chassis-1/blade-1' on host 'slgpiucs01_blade_1_1_SLGPIESX07' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 220)
Warning: Duplicate definition found for service 'Check IOM - chassis-2/slot-2' on host 'slgpiucs01_iom_2_2' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 211)
Warning: Duplicate definition found for service 'Check IOM - chassis-2/slot-1' on host 'slgpiucs01_iom_2_1' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 202)
Warning: Duplicate definition found for service 'Check IOM - chassis-1/slot-2' on host 'slgpiucs01_iom_1_2' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 193)
Warning: Duplicate definition found for service 'Check IOM - chassis-1/slot-1' on host 'slgpiucs01_iom_1_1' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 184)
Warning: Duplicate definition found for service 'Check FI - switch-B' on host '172.31.128.32_fi_B' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 175)
Warning: Duplicate definition found for service 'Check FI - switch-A' on host '172.31.128.31_fi_A' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 166)
Warning: Duplicate definition found for service 'Check CPU - chassis-2/blade-5' on host 'slgpiucs01_blade_2_5_SLGPIESX10' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 157)
Warning: Duplicate definition found for service 'Check CPU - chassis-2/blade-4' on host 'slgpiucs01_blade_2_4_SLGPIESX02' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 148)
Warning: Duplicate definition found for service 'Check CPU - chassis-2/blade-3' on host 'slgpiucs01_blade_2_3_SLGPIESX04' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 139)
Warning: Duplicate definition found for service 'Check CPU - chassis-2/blade-2' on host 'slgpiucs01_blade_2_2_SLGPIESX06' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 130)
Warning: Duplicate definition found for service 'Check CPU - chassis-2/blade-1' on host 'slgpiucs01_blade_2_1_SLGPIESX08' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 121)
Warning: Duplicate definition found for service 'Check CPU - chassis-1/blade-5' on host 'slgpiucs01_blade_1_5_SLGPIESX09' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 112)
Warning: Duplicate definition found for service 'Check CPU - chassis-1/blade-4' on host 'slgpiucs01_blade_1_4_SLGPIESX01' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 103)
Warning: Duplicate definition found for service 'Check CPU - chassis-1/blade-3' on host 'slgpiucs01_blade_1_3_SLGPIESX03' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 94)
Warning: Duplicate definition found for service 'Check CPU - chassis-1/blade-2' on host 'slgpiucs01_blade_1_2_SLGPIESX05' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 85)
Warning: Duplicate definition found for service 'Check CPU - chassis-1/blade-1' on host 'slgpiucs01_blade_1_1_SLGPIESX07' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 76)
Warning: Duplicate definition found for service 'Check Blade Server - chassis-2/blade-3' on host 'slgpiucs01_blade_2_3_SLGPIESX04' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 68)
Warning: Duplicate definition found for service 'Check Blade Server - chassis-2/blade-2' on host 'slgpiucs01_blade_2_2_SLGPIESX06' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 60)
Warning: Duplicate definition found for service 'Check Blade Server - chassis-2/blade-1' on host 'slgpiucs01_blade_2_1_SLGPIESX08' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 51)
Warning: Duplicate definition found for service 'Check Blade Server - chassis-1/blade-4' on host 'slgpiucs01_blade_1_4_SLGPIESX01' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 42)
Warning: Duplicate definition found for service 'Check Blade Server - chassis-1/blade-3' on host 'slgpiucs01_blade_1_3_SLGPIESX03' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 34)
Warning: Duplicate definition found for service 'Check Blade Server - chassis-1/blade-2' on host 'slgpiucs01_blade_1_2_SLGPIESX05' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 25)
Warning: Duplicate definition found for service 'Check Blade Server - chassis-1/blade-1' on host 'slgpiucs01_blade_1_1_SLGPIESX07' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 16)
Warning: Duplicate definition found for service 'Virtual Memory Usage' on host 'DPA_VM6_Birmingham' (config file '/usr/local/nagios/etc/services/172.31.18.15.cfg', starting on line 86)
Warning: Duplicate definition found for service 'Ping' on host 'DPA_VM6_Birmingham' (config file '/usr/local/nagios/etc/services/172.31.18.15.cfg', starting on line 69)
Warning: Duplicate definition found for service 'Physical Memory Usage' on host 'DPA_VM6_Birmingham' (config file '/usr/local/nagios/etc/services/172.31.18.15.cfg', starting on line 52)
Warning: Duplicate definition found for service 'Drive C: Disk Usage' on host 'DPA_VM6_Birmingham' (config file '/usr/local/nagios/etc/services/172.31.18.15.cfg', starting on line 34)
Warning: Duplicate definition found for service 'CPU Usage' on host 'DPA_VM6_Birmingham' (config file '/usr/local/nagios/etc/services/172.31.18.15.cfg', starting on line 16)
Warning: Duplicate definition found for service 'Virtual Memory Usage' on host 'SPDEVBOB01.olm.devon.gov.uk' (config file '/usr/local/nagios/etc/services/SPDEVBOB01.olm.devon.gov.uk.cfg', starting on line 214)
Warning: Duplicate definition found for service 'Virtual Memory Usage' on host 'SPDEVACT03.olm.devon.gov.uk' (config file '/usr/local/nagios/etc/services/SPDEVBOB01.olm.devon.gov.uk.cfg', starting on line 194)
Warning: Duplicate definition found for service 'Ping' on host 'SPDEVBOB01.olm.devon.gov.uk' (config file '/usr/local/nagios/etc/services/SPDEVBOB01.olm.devon.gov.uk.cfg', starting on line 175)
Warning: Duplicate definition found for service 'Ping' on host 'SPDEVACT03.olm.devon.gov.uk' (config file '/usr/local/nagios/etc/services/SPDEVBOB01.olm.devon.gov.uk.cfg', starting on line 156)
Warning: Duplicate definition found for service 'Physical Memory Usage' on host 'SPDEVBOB01.olm.devon.gov.uk' (config file '/usr/local/nagios/etc/services/SPDEVBOB01.olm.devon.gov.uk.cfg', starting on line 136)
Warning: Duplicate definition found for service 'Physical Memory Usage' on host 'SPDEVACT03.olm.devon.gov.uk' (config file '/usr/local/nagios/etc/services/SPDEVBOB01.olm.devon.gov.uk.cfg', starting on line 116)
Warning: Duplicate definition found for service 'Drive C: Disk Usage' on host 'SPDEVBOB01.olm.devon.gov.uk' (config file '/usr/local/nagios/etc/services/SPDEVBOB01.olm.devon.gov.uk.cfg', starting on line 76)
Warning: Duplicate definition found for service 'Drive C: Disk Usage' on host 'SPDEVACT03.olm.devon.gov.uk' (config file '/usr/local/nagios/etc/services/SPDEVBOB01.olm.devon.gov.uk.cfg', starting on line 56)
Warning: Duplicate definition found for service 'CPU Usage' on host 'SPDEVBOB01.olm.devon.gov.uk' (config file '/usr/local/nagios/etc/services/SPDEVBOB01.olm.devon.gov.uk.cfg', starting on line 36)
Warning: Duplicate definition found for service 'CPU Usage' on host 'SPDEVACT03.olm.devon.gov.uk' (config file '/usr/local/nagios/etc/services/SPDEVBOB01.olm.devon.gov.uk.cfg', starting on line 16)
Warning: Duplicate definition found for service 'CC_LIVE JNDI 2306' on host 'SPDEVFO07.olm.devon.gov.uk' (config file '/usr/local/nagios/etc/services/SPDEVFO07.olm.devon.gov.uk.cfg', starting on line 53)
Warning: Duplicate definition found for service 'Virtual Memory Usage' on host 'SPLBRFO01.olm.ad.redbridge.gov.uk' (config file '/usr/local/nagios/etc/services/SPLBRFO01.olm.ad.redbridge.gov.uk .cfg', starting on line 347)
Warning: Duplicate definition found for service 'Physical Memory Usage' on host 'SPLBRFO01.olm.ad.redbridge.gov.uk' (config file '/usr/local/nagios/etc/services/SPLBRFO01.olm.ad.redbridge.gov.uk .cfg', starting on line 290)
Warning: Duplicate definition found for service 'Ping' on host 'SLGPXSOLARIS02-Devon' (config file '/usr/local/nagios/etc/services/SLGPXDEVSOLARIS02.cfg', starting on line 89)
Warning: Duplicate definition found for service 'Memory Usage' on host 'SLGPXSOLARIS02-Devon' (config file '/usr/local/nagios/etc/services/SLGPXDEVSOLARIS02.cfg', starting on line 70)
Warning: Duplicate definition found for service '/ Disk Usage' on host 'SLGPXSOLARIS02-Devon' (config file '/usr/local/nagios/etc/services/SLGPXDEVSOLARIS02.cfg', starting on line 16)
Checking objects...
Checked 2382 services.
Checked 384 hosts.
Checked 26 host groups.
Checked 17 service groups.
Checked 42 contacts.
Checked 3 contact groups.
Checked 150 commands.
Checked 54 time periods.
Checked 0 host escalations.
Checked 384 hosts
Checked 0 host dependencies
Checked 54 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
> Return Code: 0
OUTPUT=Starting nagios: done.
RETURNCODE=0
PROCESSING COMMAND ID 14750...
PROCESS COMMAND: CMD=1150, DATA=remove
CMDLINE=php /usr/local/nagiosxi/html/includes/components/nagiosbpi/api_tool.php --cmd=syncall
CMD: syncall
MSG: Unable to match string in config file.Unable to match string in config file.Unable to match string in config file.Unable to match string in config file.BPI configuration applied successfully! Unable to match string in config file.Unable to match string in config file.Unable to match string in config file.Unable to match string in config file.BPI configuration applied successfully!
OUTPUT=MSG: Unable to match string in config file.Unable to match string in config file.Unable to match string in config file.Unable to match string in config file.BPI configuration applied successfully! Unable to match string in config file.Unable to match string in config file.Unable to match string in config file.Unable to match string in config file.BPI configuration applied successfully!
RETURNCODE=8
PROCESSED 2 COMMANDS
.......................PROCESSING COMMAND ID 14751...
PROCESS COMMAND: CMD=17, DATA=
APPLYING NAGIOSCORE CONFIG...
CMDLINE=cd /usr/local/nagiosxi/scripts && ./reconfigure_nagios.sh
--- reset_config_perms.sh ------------
> Setting CCM script permissions
> Setting script permissions
> Setting special component script permissions
> Setting configuration file/directory permissions
> Setting perfdata directory and RRD permissions
> Setting NOM checkpoint user:group permissions
> + Setting Nagios Core corelog.newobjects user:group permissions
> + Setting CCM configuration file user:group permissions
> + Setting Recurring Downtime file user:group permissions
> + Setting BPI configuration file user:group permissions
--- ccm_import.php -------------------
> Setting import directory: /usr/local/nagios/etc/import/
> Importing config files into the CCM
No files to import
--- ccm_export.php -------------------
> Writing CCM configuration to Nagios files
Finished writing out configuraton
> Verifying configuration with Nagios Core
> Output:
Nagios Core 4.4.1
Last Modified: 2018-06-25
License: GPL
Reading configuration data...
Read main config file okay...
WARNING: Extinfo objects are deprecated and will be removed in future versions
Warning: failure_prediction_enabled is obsoleted and no longer has any effect in host type objects (config file '/usr/local/nagios/etc/cisco/ucsObjs/cisco_ucs_host.cfg', starting at line 1)
Warning: failure_prediction_enabled is obsoleted and no longer has any effect in service type objects (config file '/usr/local/nagios/etc/cisco/ucsObjs/cisco_ucs_service.cfg', starting at line 1)
WARNING: The normal_check_interval attribute is deprecated and will be removed in future versions. Please use check_interval instead.
WARNING: The retry_check_interval attribute is deprecated and will be removed in future versions. Please use retry_interval instead.
Warning: Duplicate definition found for service 'Virtual Memory Usage' on host 'SPLBRFO02.olm.ad.redbridge.gov.uk' (config file '/usr/local/nagios/etc/services/SPLBRFO02.olm.ad.redbridge.gov.uk .cfg', starting on line 164)
Warning: Duplicate definition found for service 'Ping' on host 'slgtiadamg02' (config file '/usr/local/nagios/etc/services/SLGTIADAMG02.cfg', starting on line 104)
Warning: Duplicate definition found for service 'Virtual Memory Usage' on host 'STSHRAPP02' (config file '/usr/local/nagios/etc/services/STSHRAPP02.cfg', starting on line 103)
Warning: Duplicate definition found for service 'Ping' on host 'STSHRAPP02' (config file '/usr/local/nagios/etc/services/STSHRAPP02.cfg', starting on line 87)
Warning: Duplicate definition found for service 'Physical Memory Usage' on host 'STSHRAPP02' (config file '/usr/local/nagios/etc/services/STSHRAPP02.cfg', starting on line 70)
Warning: Duplicate definition found for service 'Drive D: Disk Usage' on host 'STSHRAPP02' (config file '/usr/local/nagios/etc/services/STSHRAPP02.cfg', starting on line 52)
Warning: Duplicate definition found for service 'Drive C: Disk Usage' on host 'STSHRAPP02' (config file '/usr/local/nagios/etc/services/STSHRAPP02.cfg', starting on line 34)
Warning: Duplicate definition found for service 'CPU Usage' on host 'STSHRAPP02' (config file '/usr/local/nagios/etc/services/STSHRAPP02.cfg', starting on line 16)
Warning: Duplicate definition found for service 'Ping UCS' on host 'slgpiucs01' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 328)
Warning: Duplicate definition found for service 'Check PSU - chassis-2' on host 'slgpiucs01_chassis_2' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 319)
Warning: Duplicate definition found for service 'Check Memory Array - chassis-2/blade-5' on host 'slgpiucs01_blade_2_5_SLGPIESX10' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 301)
Warning: Duplicate definition found for service 'Check Memory Array - chassis-2/blade-4' on host 'slgpiucs01_blade_2_4_SLGPIESX02' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 292)
Warning: Duplicate definition found for service 'Check Memory Array - chassis-2/blade-3' on host 'slgpiucs01_blade_2_3_SLGPIESX04' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 283)
Warning: Duplicate definition found for service 'Check Memory Array - chassis-2/blade-2' on host 'slgpiucs01_blade_2_2_SLGPIESX06' (config file '/usr/local/nagios/etc/services/services.cfg', starting on line 274)
Checking objects...
Checked 384 hosts.
Checked 384 hosts
Total Warnings: 0
Total Errors: 0
> Return Code: 0
RETURNCODE=0
PROCESSING COMMAND ID 14752...
<p class="error">Missing data from required fields. Please go back and complete all fields.</p><p class="error">Missing data from required fields. Please go back and complete all fields.</p>CMD: syncall
RETURNCODE=8
....................PROCESSING COMMAND ID 14753...
Setting new htaccess credentials
Updating password for user mphillpot
OUTPUT=
RETURNCODE=0
PROCESSED 1 COMMANDS
............................................................PHP Warning: Invalid argument supplied for foreach() in /usr/local/nagiosxi/html/includes/components/nagiosim/nagiosim.inc.php on line 491
....................PROCESSING COMMAND ID 14754...
No files to import
> Output:
Nagios Core 4.4.1
License: GPL
Reason: Please use [code][/code] tags around long output
Can you show us the FTP settings page for the scheduled backup? Also, can you try clearing the password field, re-typing your password, and saving. The upgrade changed the way the password is stored, and could possibly be the culprit.
Part 2
Checking objects...
Checked 384 hosts.
Checked 384 hosts
Total Warnings: 0
Total Errors: 0
> Return Code: 0
RETURNCODE=0
PROCESSING COMMAND ID 14755...
CMD: syncall
RETURNCODE=8
PROCESSED 0 COMMANDSRe: Nagios 5.5.1 backups going to wrong place
Part 3
I don't have access to the backup log server but I am told that it hasn't had anything new on it since the update. The test connection and test upload buttons both get successful results.
..............PROCESSING COMMAND ID 14756...
Updating password for user fabio
OUTPUT=
RETURNCODE=0
...........................PROCESSING COMMAND ID 14757...
OUTPUT=
RETURNCODE=0
.PROCESSING COMMAND ID 14758...
PROCESS COMMAND: CMD=1117, DATA=a:2:{i:0;s:19:"nagiosxi.1532008202";i:1;s:0:"";}
Backing up NRDP...
BACKUP COMPLETE
Backup stored in /store/backups/nagiosxi/nagiosxi.1532008202.tar.gz
OUTPUT=Backup stored in /store/backups/nagiosxi/nagiosxi.1532008202.tar.gz
RETURNCODE=0
............PROCESSING COMMAND ID 14759...
Updating password for user nagiosadmin
OUTPUT=
RETURNCODE=0
.............................[root@localhost martinp]# cat /usr/local/nagiosxi/var/cmdsubsys.log
New contents of /store/backups/nagiosxi
total 4336400
drwxr-xr-x 3 nagios nagios 4096 Jul 19 14:55 .
-rw-r--r-- 1 nagios nagios 1519518066 Jul 19 14:55 nagiosxi.1532008202.tar.gz
[martinp@localhost ~]$Re: Nagios 5.5.1 backups going to wrong place
Can you show us the FTP settings page for the scheduled backup as requested by jomann?
Also, run the following two commands and show the output in code wraps:
grep SB_LOGLEVEL /usr/local/nagiosxi/html/includes/constants.inc.php
cat /usr/local/nagiosxi/var/components/scheduledbackups.logBe sure to check out our Knowledgebase for helpful articles and solutions!
I can't attach images in this forum.
Update is daily at 14:50
FTP Server: 212.46.131.151
FTP Port 21
Using Passive mode
SSL Encrypted is switched off
Backup limit: 7
[root@localhost martinp]# grep SB_LOGLEVEL /usr/local/nagiosxi/html/includes/constants.inc.php
Error backing up MySQL database 'nagios' - check the password in this script!
Looks like a backup error but when I test the backup password it connects.
FTP Port 21
Using Passive mode
Backup limit: 7
Can you verify that the password that you use to connect to the nagios db is the same as the one, listed in the /usr/local/nagiosxi/html/config.inc.php file?Looks like a backup error but when I test the backup password it connects.
How do I do that, I've found the password - n@gweb but I can't see what to compare it to.
