cant make changes from gui
benhank
Post by benhank »
Im trying to disable notifications on my server(or do anything really) and I get the following:
as well as:
PROCESSED 0 COMMANDS
No log handling enabled - turning on stderr logging
/usr/local/nagioslogserver/mibs/NAGIOS-ROOT-MIB.txt: No such file or directory
/usr/local/nagioslogserver/mibs/NAGIOS-NOTIFY-MIB.txt: No such file or directory
COMMAND DATA: a:1:{s:3:"cmd";i:11;}
CORE CMD: DISABLE_NOTIFICATIONS;0
PROCESSED 1 COMMANDS
the interesting part is when I open
/usr/local/nagios/etc/nagios.cfg
enable_notifications=0
but in the gui it's green
Oh, I installed and uninstalled nls on this server a while ago and ever since ive been getting those logging messages but it hasn't been a problem so far.
Proudly running:
Nagios Network Analyser
Nagios Fusion
Re: cant make changes from gui
What version are you running Ben?
Lets start by trying this:
service nagios stop
killall -9 nagios
rm -f /usr/local/nagios/var/rw/nagios.cmd
service nagios start
If that doesn't work I would open a ticket and send a profile.
benhank
Post by benhank »
i upgraded to 5.5 but it didn't go well so i restored to 5.4.12
Proudly running:
Nagios Fusion
benhank
Post by benhank »
update I just upgraded toNagios XI 5.4.13
using the upgrade -f parameter
Then I re ran the lines supplied and the issue persists
Proudly running:
Nagios Fusion
benhank
Post by benhank »
before i do a tkt I'm gonna trying to reinstall and do a restore, I think something went wrong with the initial restore as I was haveing probleblems with nagios.lock and used the forums to fix it.
on a side note Scott how do I get rid of that logging error since its looking for nls which is no longer on the server?
THANKs!
Proudly running:
Nagios Fusion
my steps above could get rid of that if you have a bad nagios.cmd pipe
sorry, I see the error you are talking about... not sure what is looking for those mibs
Can you run this
grep -R nagioslogserver /etc/snmp
benhank
Post by benhank »
it comes up blank:
[root@Lkennagiost01 nagiosxi]# grep -R nagioslogserver /etc/snmp
Proudly running:
Nagios Fusion
lets look higher
benhank
Post by benhank »
here yah go:
/etc/cron.d/nagioslogserver:# /etc/cron.d/nagioslogserver: crontab fragment for nagioslogserver
/etc/cron.d/nagioslogserver:* * * * * nagios /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php poller > /usr/local/nagioslogserver/var/poller.log 2>&1
/etc/cron.d/nagioslogserver:* * * * * nagios /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs > /usr/local/nagioslogserver/var/jobs.log 2>&1
/etc/cron.d/nagioslogserver:0 * * * * nagios /usr/bin/php -q /var/www/html/nagioslogserver/www/index.php jobs/hosts > /usr/local/nagioslogserver/var/hosts.log 2>&1
/etc/sysconfig/logstash:APP_DIR=/usr/local/nagioslogserver
/etc/sysconfig/logstash:        GET_LOGSTASH_CONFIG_MESSAGE=$( php /usr/local/nagioslogserver/scripts/get_logstash_config.php )
/etc/sysconfig/elasticsearch:APP_DIR="/usr/local/nagioslogserver"
/etc/rc0.d/K10logstash:LS_HOME=/usr/local/nagioslogserver/$NAME
/etc/rc0.d/K20elasticsearch:ES_HOME=/usr/local/nagioslogserver/elasticsearch
/etc/rc1.d/K10logstash:LS_HOME=/usr/local/nagioslogserver/$NAME
/etc/rc1.d/K20elasticsearch:ES_HOME=/usr/local/nagioslogserver/elasticsearch
/etc/rc3.d/S90logstash:LS_HOME=/usr/local/nagioslogserver/$NAME
/etc/rc3.d/S80elasticsearch:ES_HOME=/usr/local/nagioslogserver/elasticsearch
/etc/rc6.d/K10logstash:LS_HOME=/usr/local/nagioslogserver/$NAME
/etc/rc6.d/K20elasticsearch:ES_HOME=/usr/local/nagioslogserver/elasticsearch
/etc/rc5.d/S90logstash:LS_HOME=/usr/local/nagioslogserver/$NAME
/etc/rc5.d/S80elasticsearch:ES_HOME=/usr/local/nagioslogserver/elasticsearch
/etc/rc.d/rc0.d/K10logstash:LS_HOME=/usr/local/nagioslogserver/$NAME
/etc/rc.d/rc0.d/K20elasticsearch:ES_HOME=/usr/local/nagioslogserver/elasticsearch
/etc/rc.d/rc1.d/K10logstash:LS_HOME=/usr/local/nagioslogserver/$NAME
/etc/rc.d/rc1.d/K20elasticsearch:ES_HOME=/usr/local/nagioslogserver/elasticsearch
/etc/rc.d/rc3.d/S90logstash:LS_HOME=/usr/local/nagioslogserver/$NAME
/etc/rc.d/rc3.d/S80elasticsearch:ES_HOME=/usr/local/nagioslogserver/elasticsearch
/etc/rc.d/rc6.d/K10logstash:LS_HOME=/usr/local/nagioslogserver/$NAME
/etc/rc.d/rc6.d/K20elasticsearch:ES_HOME=/usr/local/nagioslogserver/elasticsearch
/etc/rc.d/rc5.d/S90logstash:LS_HOME=/usr/local/nagioslogserver/$NAME
/etc/rc.d/rc5.d/S80elasticsearch:ES_HOME=/usr/local/nagioslogserver/elasticsearch
/etc/rc.d/rc4.d/K10logstash:LS_HOME=/usr/local/nagioslogserver/$NAME
/etc/rc.d/rc4.d/K20elasticsearch:ES_HOME=/usr/local/nagioslogserver/elasticsearch
/etc/rc.d/init.d/logstash:LS_HOME=/usr/local/nagioslogserver/$NAME
/etc/rc.d/init.d/elasticsearch:ES_HOME=/usr/local/nagioslogserver/elasticsearch
/etc/rc.d/rc2.d/K10logstash:LS_HOME=/usr/local/nagioslogserver/$NAME
/etc/rc.d/rc2.d/K20elasticsearch:ES_HOME=/usr/local/nagioslogserver/elasticsearch
/etc/rc4.d/K10logstash:LS_HOME=/usr/local/nagioslogserver/$NAME
/etc/rc4.d/K20elasticsearch:ES_HOME=/usr/local/nagioslogserver/elasticsearch
/etc/init.d/logstash:LS_HOME=/usr/local/nagioslogserver/$NAME
/etc/init.d/elasticsearch:ES_HOME=/usr/local/nagioslogserver/elasticsearch
/etc/rc2.d/K10logstash:LS_HOME=/usr/local/nagioslogserver/$NAME
/etc/rc2.d/K20elasticsearch:ES_HOME=/usr/local/nagioslogserver/elasticsearch
/etc/sudoers:NAGIOSLOGSERVER ALL = NOPASSWD:/usr/local/nagioslogserver/scripts/change_timezone.sh
/etc/sudoers:NAGIOSLOGSERVERWEB ALL = NOPASSWD:/usr/local/nagioslogserver/scripts/get_logstash_ports.sh
/etc/httpd/conf.d/nagioslogserver.conf:Alias /nagioslogserver "/var/www/html/nagioslogserver/www/"
/etc/httpd/conf.d/nagioslogserver.conf:<Directory "/var/www/html/nagioslogserver/www/">
/etc/httpd/conf.d/nagioslogserver.conf:RewriteRule nagioslogserver/(.*)$ /var/www/html/nagioslogserver/www/index.php/$1 [L,QSA]
/etc/httpd/logs/error_log-20180708:/usr/local/nagioslogserver/mibs/NAGIOS-ROOT-MIB.txt: No such file or directory
/etc/httpd/logs/error_log-20180708:/usr/local/nagioslogserver/mibs/NAGIOS-NOTIFY-MIB.txt: No such file or directory
/etc/httpd/logs/error_log-20180701:/usr/local/nagioslogserver/mibs/NAGIOS-ROOT-MIB.txt: No such file or directory
/etc/httpd/logs/error_log-20180701:/usr/local/nagioslogserver/mibs/NAGIOS-NOTIFY-MIB.txt: No such file or directory
/etc/httpd/logs/error_log-20180715:/usr/local/nagioslogserver/mibs/NAGIOS-ROOT-MIB.txt: No such file or directory
/etc/httpd/logs/error_log-20180715:/usr/local/nagioslogserver/mibs/NAGIOS-NOTIFY-MIB.txt: No such file or directory
Proudly running:
Nagios Fusion
