As checked, we are getting fake alerts for few node.
[root@nagiosxi libexec]# su - nagios
[nagios@nagiosxi ~]$ cd /usr/local/nagios/libexec
[nagios@nagiosxi libexec]$ ./check_snmp_load_wizard.pl -H HCSMS1 -C public --v2c -w 90 -c 95 -T netsc -f CPU used 100.0% (>95) : CRITICAL | cpu_prct_used=100%;90;95
[nagios@nagiosxi libexec]$ date
Thu Jul 19 12:00:47 ICT 2018
[nagios@nagiosxi libexec]$ ssh HCSMS1
Last login: Wed Jul 18 12:21:03 2018 from 10.10.164.52
[nagios@HCSMS1 ~]$ uptime
11:55:35 up 905 days, 15:57, 2 users, load average: 0.86, 0.69, 0.61
[nagios@HCSMS1 ~]$ date
Thu Jul 19 11:55:38 ICT 2018
[nagios@HCSMS1 ~]$
[nagios@HCSMS1 ~]$
[nagios@HCSMS1 ~]$ logout
Connection to HCSMS1 closed.
[nagios@nagiosxi libexec]$ ./check_snmp_load_wizard.pl -H HCSMS1X4 -C public --v2c -w 90 -c 95 -T netsc -f
[nagios@nagiosxi libexec]$ ssh HCSMS1X4
Last login: Wed Jun 13 18:16:52 2018 from 10.10.164.52
[nagios@hcsms1x4 ~]$ uptime
12:02:26 up 735 days, 10:56, 2 users, load average: 0.38, 0.42, 0.31
[nagios@hcsms1x4 ~]$ date
Thu Jul 19 12:02:28 ICT 2018
we are getting 100% CPU load in the alert window. As checked, the load is normal. Please suggest. This check works fine for all the nodes except these nodes. It is considering idle CPU. Please suggest the way forward to get rid of the same.
CPU load || Fake Alert
ericssonvietnam
Re: CPU load || Fake Alert
What kinds of nodes are these (OS)?
You may need to change -T netsc to one of the other options
-T, --type=stand|netsl|netsc|as400|cisco|bc|nokia|hp|lp
CPU check :
stand : standard MIBII (works with Windows),
can handle multiple CPU.
netsl : linux load provided by Net SNMP (1,5 & 15 minutes values)
netsc : cpu usage given by net-snmp (100-idle)
as400 : as400 CPU usage
cisco : Cisco CPU usage
cata : Cisco catalyst CPU usage
nsc : NetScreen CPU usage
fg : Fortigate CPU usage
bc : Bluecoat CPU usage
nokia : Nokia CPU usage
hp : HP procurve switch CPU usage
lp : Linkproof CPU usage
hpux : HP-UX load (1,5 & 15 minutes values)
