A simple question about simple notification
davide.bonicelli
Post by davide.bonicelli »
Hi, after upgrading to latest nagiosxi version 5.5.1 (or i think so) for some service i haven't recovery notification..
that's the history:
11:06:59 notification about service down of the host server.ok.com
11:10:35 notification about host server.ok.com down
11:16:48 notification about host server.ok.com recovery
..still waiting for recovery service notification that was ok in the same moment that host back up
notification config is this:
jomann
Development Lead
Re: A simple question about simple notification
Post by jomann »
Can we see the template that is applied too, the skip implies it will be inheriting the value from templates and won't actually write that configuration option out.
davide.bonicelli
i can see the template applied from Service Management->Common Settings->Manage Templates , correct?
it's the same..
jomann
Development Lead
Post by jomann »
Check in the service template where the templates are applied. You can have templates inherit from templates. You can also check in the objects.cache file in /usr/local/nagios/var/ to see the completed object, with all inherited data defined.
Returning to the original post though, you should be able to click the "Recovery" option in the Alert Settings in your first picture. That would make sure that specific service would notify on recovery. I would also click on "On" for Notification enabled too, to ensure that notifications are enabled.
davide.bonicelli
Thanks jomann, you're right there was a template in the template..but same conditions:
and nothing in the objects.cache file:
        host_name       nagios_DustyRendering
        service_description     Nagios XI Daemons
        check_period    xi_timeperiod_24x7
        check_command   check_xi_nagiosxiserver!--address=x.x.x.x --url=https://x.x.x.x:4443/nagiosxi --username=nagiosadmin --ticket="xxxxx" --mode=daemons
        contact_groups  Monitoraggio-PRO,Monitoraggio
        notification_period     xi_timeperiod_24x7
        initial_state   o
        importance      0
        check_interval  10.000000
        retry_interval  1.000000
        max_check_attempts      5
        is_volatile     0
        parallelize_check       1
        active_checks_enabled   1
        passive_checks_enabled  1
        obsess  1
        event_handler_enabled   1
        low_flap_threshold      0.000000
        high_flap_threshold     0.000000
        flap_detection_enabled  1
        flap_detection_options  a
        freshness_threshold     0
        check_freshness 0
        notification_options    a
        notifications_enabled   1
        notification_interval   480.000000
        first_notification_delay        0.000000
        stalking_options        n
        process_perf_data       1
        retain_status_information       1
        retain_nonstatus_information    1
        _XIWIZARD       nagiosxiserver
surely i could change the option for this service but i want do it for all the service i have..
jomann
Development Lead
Post by jomann »
Well the place you'd probably want to change it at is one of the templates, or you can create a new template and apply the template to the services that you want to give that option to. From what I can tell, XI's default inheritance is two templates. They should have all notification_options enabled by default. We will need to test this here, if you want I would also verify on your system that if you do set the recovery option on a service that the service does notify you. If it doesn't, it is either the configuration or a bug some where.
davide.bonicelli
i tried to modify the template and the singular service notification option, enabling all (notification options and notification enabled putting it on) but it doesn't help..i suspect a bug..
Is it still showing incorrect in objects.cache? Did you apply configuration after making the change?
davide.bonicelli
Sure i applied the configuration after the change.
what does it mean the 'a'
in objects.cache?
davide.bonicelli wrote:Sure i applied the configuration after the change.
in objects.cache?
all
