Uninstall nagios network analyzer on Linux
dais
Post by dais »
I have installed nagios following this guide: https://assets.nagios.com/downloads/nag ... 1532076035
I have also tried to uninstall it with script uninstall_xi.sh downloaded from here: https://support.nagios.com/forum/viewto ... f=6&t=7102
It shows:
        !! DESTRUCTIVE UNINSTALL NOTICE !!
        WARNING: This script will uninstall
        Nagios
        MySql
        Postgresql
        from this system as well as all data associated with these services.
        This action is irreversible and will result in the removal of
        all Nagios databases, configuration files, log files, and services.
Are you sure you want to continue? [y/N] y
Proceeding with uninstall...
Stopping services...
Failed to stop nagios.service: Unit nagios.service not loaded.
Failed to stop npcd.service: Unit npcd.service not loaded.
Failed to stop ndo2db.service: Unit ndo2db.service not loaded.
removing init files...
Removing users and suduoers...
userdel: user 'nagios' does not exist
groupdel: group 'nagcmd' does not exist
Removing crontabs...
Removing files...
Removing NagiosQL files...
Removing Apache configs...
Failed to restart httpd.service: Unit httpd.service not found.
Removing xinetd configs...
Failed to restart xinetd.service: Unit xinetd.service not found.
Removing Postgres and mysql databases...
uninstall_xi.sh: line 80: yum: command not found
Removing database backup scripts...
        UNINSTALL COMPLETED!
and when I run again ./fullinstall, it shows:
It looks like Nagios Network Analyzer is already installed.
Re: Uninstall nagios network analyzer on Linux
We recommend installing on a fresh minimal install system.
dais
Post by dais »
Why not on the same system?
dais
Post by dais »
Why do I need to do a fresh minimal install system?
We do not have a script that clean up and removes all the databases, directories and packages from the original install. and you would be left with fragments of files, logs etc that would not be relevant to the current install causing confusion.
dais
Post by dais »
So basically, there is no way to uninstall it?
dais wrote:So basically, there is no way to uninstall it?
That is correct. You could remove the directories but there are other additions that will still be present
rm -rf /usr/local/nagiosna
rm -rf /var/www/html/nagiosna
dais
Post by dais »
Okay.. I've done
sudo rm -rf /usr/local/nagiosna
sudo rm -rf /var/www/html/nagiosna/
and
sudo rm /etc/init.d/nagiosna
also delete extracted nagiosna folder
and follow installation guide again.
It is installed successfully !!
NOTE: mysql-server should be installed correctly with root password.
dais wrote:Okay.. I've done
and
Great!
Locking
