NagiosXI Upgrade 5.4.13 to 5.5 failed
I cannot upgrade nagios.
I receive the message :
No package shellinabox available.
Error: Nothing to do
Could you help me ?
Regards.
Could you help me ?
Regards.
Re: NagiosXI Upgrade 5.4.13 to 5.5 failed
Can you run
and display the output
yum list reposRe: NagiosXI Upgrade 5.4.13 to 5.5 failed
Hi
Here it's :
Here it's :
Loaded plugins: enabled_repos_upload, package_upload, product-id, search-disabled-repos, security, subscription-manager
Repo evs-sci_EVS_networker-client-x86_64 forced skip_if_unavailable=True due to: /etc/pki/entitlement/3994093472834726237-key.pem
Repo rhel-6-server-satellite-tools-6.3-rpms forced skip_if_unavailable=True due to: /etc/pki/entitlement/2666211591344503021-key.pem
Repo rhel-6-server-rpms forced skip_if_unavailable=True due to: /etc/pki/entitlement/2666211591344503021-key.pem
Repo rhel-6-server-supplementary-rpms forced skip_if_unavailable=True due to: /etc/pki/entitlement/2666211591344503021-key.pem
Repo rhel-6-server-extras-rpms forced skip_if_unavailable=True due to: /etc/pki/entitlement/2666211591344503021-key.pem
Repo rhel-6-server-optional-rpms forced skip_if_unavailable=True due to: /etc/pki/entitlement/2666211591344503021-key.pem
https://rhs-p01.infra.vs.ch/pulp/repos/evs-sci/Library/custom/EVS/networker-client-x86_64/repodata/repomd.xml: [Errno 14] problem with the local client certificate
Trying other mirror.
evs-sci_EVS_networker-client-x86_64 3/3
nagios-base 161/161
nagiosxi-deps 35/35
https://rhs-p01.infra.vs.ch/pulp/repos/evs-sci/Library/content/dist/rhel/server/6/6Server/x86_64/extras/os/repodata/repomd.xml: [Errno 14] problem with the local client certificate
rhel-6-server-extras-rpms 89/89
https://rhs-p01.infra.vs.ch/pulp/repos/evs-sci/Library/content/dist/rhel/server/6/6Server/x86_64/optional/os/repodata/repomd.xml: [Errno 14] problem with the local client certificate
rhel-6-server-optional-rpms 11847/11847
https://rhs-p01.infra.vs.ch/pulp/repos/evs-sci/Library/content/dist/rhel/server/6/6Server/x86_64/os/repodata/repomd.xml: [Errno 14] problem with the local client certificate
rhel-6-server-rpms 20464/20464
https://rhs-p01.infra.vs.ch/pulp/repos/evs-sci/Library/content/dist/rhel/server/6/6Server/x86_64/sat-tools/6.3/os/repodata/repomd.xml: [Errno 14] problem with the local client certificate
rhel-6-server-satellite-tools-6.3-rpms 32/32
https://rhs-p01.infra.vs.ch/pulp/repos/evs-sci/Library/content/dist/rhel/server/6/6Server/x86_64/supplementary/os/repodata/repomd.xml: [Errno 14] problem with the local client certificate
rhel-6-server-supplementary-rpms 828/828
Error: No matching Packages to list
Uploading Enabled Repositories Report
Loaded plugins: product-id
Cannot upload enabled repos report, is this client registered?
Looks like you have incorrect keys for your entitlements from RedHat, they have an article here of how to resolve the issue
https://access.redhat.com/solutions/1584403
Sorry I didn't had sufficient privilege when running "yum list repos" (shame on me)!
Here you are :
Here you are :
# yum list repos
evs-sci_EVS_networker-client-x86_64 | 2.1 kB 00:00
Not using downloaded repomd.xml because it is older than what we have:
Current : Mon May 8 11:00:48 2017
Downloaded: Wed Apr 19 08:46:04 2017
rhel-6-server-extras-rpms | 1.8 kB 00:00
rhel-6-server-optional-rpms | 2.0 kB 00:00
rhel-6-server-rpms | 2.0 kB 00:00
rhel-6-server-satellite-tools-6.3-rpms | 2.1 kB 00:00
rhel-6-server-supplementary-rpms | 2.0 kB 00:00
You have mail in /var/spool/mail/root
But errors with "yum list repos" seems to be du to syntax and with "yum repolist" I have no error.
#yum repolist
repo id repo name status
evs-sci_EVS_networker-client-x86_64 networker-client-x86_64 4
nagios-base Nagios 161
nagiosxi-deps Nagios XI Dependencies 35
rhel-6-server-extras-rpms Red Hat Enterprise Linux 6 Server - Extras (RPMs) 89
rhel-6-server-optional-rpms Red Hat Enterprise Linux 6 Server - Optional (RPMs) 11,847
rhel-6-server-rpms Red Hat Enterprise Linux 6 Server (RPMs) 20,464
rhel-6-server-satellite-tools-6.3-rpms Red Hat Satellite Tools 6.3 (for RHEL 6 Server) (RPMs) 32
rhel-6-server-supplementary-rpms Red Hat Enterprise Linux 6 Server - Supplementary (RPMs) 828
repolist: 33,460
your system doesn't have the epel repository installed, someone must have removed it. or disabled it
please run
please run
ls -al /etc/yum.repo.dRe: NagiosXI Upgrade 5.4.13 to 5.5 failed
Thanks for your help.Nagios XI Upgrade Complete!
excellent, glad it is resolvedchrtap wrote:Thanks for your help.Nagios XI Upgrade Complete!
Locking
