do you have the Nagios plugins for XenServer release 6.5.0-90233c
the want me to have Nagios monitor disk space on it, and I'm not finding any RPMs for Xen Servers
thank you in advance
Xen Server plugins
Re: Xen Server plugins
We have the following plugins listed on the Nagios Exchange
https://exchange.nagios.org/directory/P ... nments/Xen
I'm sorry, I meant the standard set of plugins but for a Xen Server, if it has a /etc/redhat-release would it not have plugins that would work on it?
Oh for sure, you can use the following
https://assets.nagios.com/downloads/nag ... _Agent.pdf
and then use the Linux Monitoring Wizard
Or, you can use NCPA which is RPM based
https://www.nagios.org/ncpa/getting-sta ... pm-install
and then the NCPA Wizard
ok, thank you, you can close this
Lockingjenstar13 wrote:ok, thank you, you can close this
