Nagios Core- Snmptt service status failed
sannatar16
Post by sannatar16 »
I am trying to configure nagios server to process snmp traps from nw devices. I have installed nsti and snmptt as well.
When I am sending any test trap it is not logged under /var/log/snmptt folder. I see only snmpsystem.log in this folder.
In /var/log/messages, seeing the below error when sending snmp trap
Jul 24 08:07:55 xxxxxxxxxxx snmptt-sys[79834]: MySQL error: Unable to connect to database: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.soc
k' (2)
service snmptt status
Redirecting to /bin/systemctl status snmptt.service
? snmptt.service - SNMP Trap Translator (SNMPTT)
Loaded: loaded (/usr/lib/systemd/system/snmptt.service; disabled; vendor pres et: disabled)
Active: active (running) since Mon 2018-07-23 08:42:00 UTC; 23h ago
Process: 79666 ExecStart=/usr/sbin/snmptt --daemon (code=exited, status=0/SUCC ESS)
Main PID: 79669 (snmptt)
CGroup: /system.slice/snmptt.service
+-79668 /usr/bin/perl /usr/sbin/snmptt --daemon
+-79669 /usr/bin/perl /usr/sbin/snmptt --daemon
Jul 24 07:02:04 xxxxxxxxx snmptt-sys[79669]: MySQL error: Unable to conne...)
Jul 24 07:07:04 xxxxxxxxx snmptt-sys[79669]: MySQL error: Unable to conne...)
Jul 24 07:12:04 xxxxxxxxx snmptt-sys[79669]: MySQL error: Unable to conne...)
Jul 24 07:17:04 xxxxxxxxx snmptt-sys[79669]: MySQL error: Unable to conne...)
Jul 24 07:22:04 xxxxxxxxx snmptt-sys[79669]: MySQL error: Unable to conne...)
Jul 24 07:27:04 xxxxxxxxx snmptt-sys[79669]: MySQL error: Unable to conne...)
Jul 24 07:32:04 xxxxxxxxx snmptt-sys[79669]: MySQL error: Unable to conne...)
Jul 24 07:37:04 xxxxxxxxx snmptt-sys[79669]: MySQL error: Unable to conne...)
Jul 24 07:42:04 xxxxxxxxx snmptt-sys[79669]: MySQL error: Unable to conne...)
Jul 24 07:47:04 xxxxxxxxx snmptt-sys[79669]: MySQL error: Unable to conne...)
Please assist me what I am missing here.
Thanks in advance
Re: Nagios Core- Snmptt service status failed
Is the MYSQL database running on the server?
The test trap tries to add an entry in to the MYSQL database and it may not be running.
Also, did you edit the /etc/snmp/snmptt.ini file and add the MYSQL database credentials?
Can you post the file here?
