Free variable empty
sib
Free variable empty
Post by sib »
Hi
I defined a command which uses free variables
The commands looks like this
/usr/bin/printf "%b" "***** Nagios Monitor XI Alert *****\n\n$_HOSTCUSTOM_MESSAGE$" | /bin/mail -s "Nagios Alert: $_HOSTCUSTOM_SUBJECT$" $CONTACTEMAIL$
Then I defined a service that uses that alert notification command and defined 2 free variables
When the alert comes it has a subject "Nagios Alert: $" It does not show the content of the free variable.
Nagios XI 5.4.13
Re: Free variable empty
I haven't been able to recreate the issue in house.
If these are service free variables, instead of using the command below:
you should be using:
/usr/bin/printf "%b" "***** Nagios Monitor XI Alert *****\n\n$_SERVICECUSTOM_MESSAGE$" | /bin/mail -s "Nagios Alert: $_SERVICECUSTOM_SUBJECT$" $CONTACTEMAIL$
Can you show us the actual notification email, and the configuration file for the "problem" service?
