Nagios and highcharts.
benhank
Post by benhank »
Is it possible to change the looks of the highcharts graps in XI?
OR
is there a way to add more graphing options here via highcharts:
Proudly running:
Nagios Network Analyser
Nagios Fusion
Re: Nagios and highcharts.
There is no way to add more than those listed in the dropdown.
benhank
Post by benhank »
is there a way (supported by nagios) to change the look of the charts?
Proudly running:
Nagios Fusion
benhank wrote:is there a way (supported by nagios) to change the look of the charts?
Ony with the dropdown you highlighted in your image
benhank
Post by benhank »
ok! thanks you can lock it up!
Proudly running:
Nagios Fusion
benhank wrote:ok! thanks you can lock it up!
Locking
