[nagios@nagiosprodcol2 nagiosxi]$ sudo ./upgrade
Archive: sourceguardian/ixed4.lin.x86-64.zip
inflating: /usr/lib64/php/modules/ixed.5.3.lin
Sourceguardian extension found for PHP version 5.3
Sourceguardian extension already in php.ini
Stopping httpd: [ OK ]
Starting httpd: httpd: Could not reliably determine the server's fully qualified domain name, using 10.17.19.226 for ServerName
[ OK ]
Checking required prereqs...
Please wait...
OLD VERSION: 5413
Loaded plugins: product-id, search-disabled-repos, security, subscription-
: manager
Setting up Update Process
No Packages marked for Update
: manager
Setting up Install Process
Package perl-Test-Simple-0.92-144.el6.x86_64 already installed and latest version
Package perl-Params-Validate-0.92-3.el6.x86_64 already installed and latest version
Package perl-Config-Tiny-2.12-7.1.el6.noarch already installed and latest version
Resolving Dependencies
--> Running transaction check
---> Package perl-Class-Accessor.noarch 0:0.31-6.1.el6 will be updated
---> Package perl-Class-Accessor.noarch 0:0.34-12.el7 will be an update
--> Processing Dependency: perl(:MODULE_COMPAT_5.16.3) for package: perl-Class-Accessor-0.34-12.el7.noarch
---> Package perl-Math-Calc-Units.noarch 0:1.07-6.el6 will be updated
---> Package perl-Math-Calc-Units.noarch 0:1.07-9.el7 will be an update
--> Processing Dependency: perl(:MODULE_COMPAT_5.16.3) for package: perl-Math-Calc-Units-1.07-9.el7.noarch
---> Package perl-Number-Format.noarch 0:1.73-3.el6 will be updated
---> Package perl-Number-Format.noarch 0:1.73-14.el7 will be an update
--> Processing Dependency: perl(:MODULE_COMPAT_5.16.3) for package: perl-Number-Format-1.73-14.el7.noarch
Error: Package: perl-Class-Accessor-0.34-12.el7.noarch (epel)
Requires: perl(:MODULE_COMPAT_5.16.3)
Error: Package: perl-Math-Calc-Units-1.07-9.el7.noarch (epel)
Error: Package: perl-Number-Format-1.73-14.el7.noarch (epel)
Dependency resolving failed due to missing dependencies.
Some repositories on your system are disabled, but yum can enable them
and search for missing dependencies. This will require downloading
metadata for disabled repositories and may take some time and traffic.
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
[nagios@nagiosprodcol2 nagiosxi]$ cat /etc/redhat-release
Red Hat Enterprise Linux Server release 6.9 (Santiago)
