Unable to Apply the Configuration
yangzhiyao2653
Very suddenly, can't the application configuration.I checked the background and on the web logs, no show special operations.In this situation should how to troubleshoot, please?I try to restore a configuration on the snapshots cannot solve, check the system status, found that there are several abnormalities.
Re: Unable to Apply the Configuration
What is the output of the following:
chage -l nagios
grep nagios /var/log/cron|tail -10
