Bulk Host Cloning and Import doesn't work
hchen
Post by hchen »
Dear Support,
We are having issue with the "Bulk Host Cloning and Import" feature, it looks like the host config file generated by Nagios is incomplete. Please see below for the details.
Please advise.
Nagios Core 4.4.1
Last Modified: 2018-06-25
License: GPL
Reading configuration data...
Read main config file okay...
Error: Invalid max_check_attempts value for host 'mysalt.xxx.com'
Error: Could not register host (config file '/usr/local/nagios/etc/hosts/mysalt.xxx.com.cfg', starting on line 16)
directives and data definitions. If you are upgrading from a previous
Incomplete host config file:
# Hosts configuration file
# Created by: Nagios CCM 2.7.0
# Date: 2018-07-27 20:25:20
# Version: Nagios Core 4.x
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
define host {
host_name mysalt.xxx.com
use generic-host
address mysalt.xxx.com
register 1
# END OF FILE
Correct host config file looks like this:
# Host configuration file
# Created by: Nagios Core Config Manager 2.6.5
# Date: 2017-03-16 15:44:57
# Version: Nagios 3.x config file
define host {
host_name app10.xxx.com
use xiwizard_linuxserver_host
address app10.xxx.com
max_check_attempts 5
check_interval 5
retry_interval 1
check_period 24x7
contact_groups admins
notification_interval 60
notification_period 24x7
notifications_enabled 1
register 1
# END OF FILE
Re: Bulk Host Cloning and Import doesn't work
Could you send a screenshot of the screen where you are selecting the services in the wizard?
hchen
Post by hchen »
scottwilkerson wrote:Could you send a screenshot of the screen where you are selecting the services in the wizard?
Thanks for the rely, just pm you the screenshot, basically I selected all items from another host, but it doesn't matter how many items you select, it will just fail.
Based on your screenshot you did not select the Name field which is the host_name and onle entered the address field, Name is required and it is the minimum required.
I admit, that this should be documented on the page better, and will request so from out developers
Can you try again selecting the Name field in the first dropdown.
hchen
Post by hchen »
I tried to add the name field from the drop down list, in this case, it's the hostname. The result is the same. We never added name field before and it worked just fine. This feature was broken for the last 3 releases. I wonder whether you are able to re-produce it on your side.
After consulting with the developers about the cause of this, we did come up with a cause and that is the file format changes slightly in the newer versions and need to be re-written to be parsed correctyl.
Lets to the following. Remove the erroneous configs for the host/services, in the CCM.
Then
CCM -> Tools -> Config File Management
Delete Files
Write Configs
Verify Files
Restart Nagios Core
This will reset the configs
Now, the Bulks Host Import Wizard should work correctly.
hchen
Re: Bulk Host Cloning and Import doesn't work [solved]
Post by hchen »
Great! It's working now. Really appreciate it.
hchen wrote:Great! It's working now. Really appreciate it.
Glad to hear it is resolved!
Locking
