Query pnp4nagios
alex3105
Query pnp4nagios
Post by alex3105 »
I have Centos 7 and pnp4 installed, the query is every time I restart my server the graphics are also restarted not allowing to see the previous graphics .. so it works or I need to configure something to be able to have historical information with pnp of my servers.
Best regards..
Re: Query pnp4nagios
Are you storing the .rrd files in a /tmp directory that is getting deleted when you restart the server?
alex3105
Post by alex3105 »
they are stored by default
alex3105 wrote:they are stored by default
In what file location?
alex3105
Post by alex3105 »
Good morning..
my installation path is /usr/local/pnp/nagios/...
Greetings..
and the RRD files disappear when you reboot?
Post by mcapra »
Based on my very brief reading of the pnp4nagios configuration documentation, $conf['rrdbase'] should tell us where the RRDs are being pulled into pnp4nagios from. If that is any sort of transient/temporary storage, that may be your problem.
Your process_perfdata.cfg might also have some clues.
As a reminder, this is a Nagios Core support forum. pnp4nagios is a 3rd party product that has their own community (mailing lists).
mcapra wrote:Based on my very brief reading of the pnp4nagios configuration documentation, $conf['rrdbase'] should tell us where the RRDs are being pulled into pnp4nagios from. If that is any sort of transient/temporary storage, that may be your problem.
Thanks for adding this, being we do not author or manage pnp4nagios, this question would be better suited for them.
alex3105
Post by alex3105 »
Ok .. thanks anyway ... I'll keep investigating--
Best Regards..
ok
