Help Nagios with vmware
alex3105
Post by alex3105 »
Good morning ... I am following this guide to monitor my vmware
http://www.bujarra.com/nagios-monitorizando-hosts-esxi/
but I get this error:
[root@localhost libexec]# ./check_vmware_api.pl -H 192.168.32.7 -f check_vmware_api.auth -l cpu -s usage -w 80 -c 90
/usr/bin/perl: symbol lookup error: /usr/lib64/perl5/auto/Crypt/SSLeay/SSLeay.so: undefined symbol: Perl_Gthr_key_ptr
I have Centos 7 of 64 bits ... could you indicate that I would be unable to add please ..
Greetings from Perú..
Re: Help Nagios with vmware
Post by mcapra »
As this is 3rd party documentation and a 3rd party plugin, the support you receive on these forums may be limited. This is not strictly a Nagios Core related problem; I am almost positive this is a problem with your Perl environment.
Can you share the output of the following command executed from the CLI of your Nagios Core machine:
rpm -qa | grep perl
cpan -l
perl --version
I'm thinking your perl-Digest-SHA package version is mis-matched with your perl package version, based on my limited reading.
It looks like the perl-Crypt-SSLeay package is missing from your server.
Run this as root to install it.
yum install perl-Crypt-SSLeay -y
Then test the plugin again to see if it works.
alex3105
Post by alex3105 »
Dear tgriep,
The output of the indicated files is shared,
Greetings.
txt.txt
(196.37 KiB) Downloaded 618 times
alex3105
Post by alex3105 »
Dear tgriep,
After executing yum install perl-Crypt-SSLeay -y I get this result:
[root@localhost libexec]# ./check_vmware_api.pl -H 192.168.32.7 -f check_vmware_api.auth -l mem -s swap -w 1 -c 10
length() used on @array (did you mean "scalar(@array)"?) at /usr/lib64/perl5/IO/Compress/Zlib/Extra.pm line 198, <AUTH_FILE> line 2.
CHECK_VMWARE_API.PL OK - swap usage=0.00 MB | mem_swap=0.00MB;1;10
Greetings.
It looks like it could be a formatting issue with the auth file so check that to see it it is correct.
It should be setup like this
username=nagiosadmin
password=nagiosadmin
Also, is could be caused by an older version of the IO::Compress::Zlib::Extra Perl module.
Make sure you update that.
alex3105
Post by alex3105 »
For this last you could indicate the command to update ..
This command should update that Perl module for you.
cpan -i  IO::Compress::Zlib::Extra
You can look at this link on installing Perl modules using cpan.
http://www.cpan.org/modules/INSTALL.html
