Is there a way to configure the session timeout/idle timeout for my http://myserver connection ?
Session time out
Re: Session time out
What version of XI are you using?
Is it a VM or source install?
Is the date correct on the XI server?
http://support.nagios.com/wiki/index.ph ... _To_Itself
It's Nagios XI 2011R1.6 virtual machine.
the XI server time is sync and GMT. I'm using UTC+2 time zone station to connect to it.
Almost every morning when I arrive to work I see "your session has timed out".
No way that I know of to change that, it basically only expires if it doesn't (or cannot) make an update for 30 minutes.
Where can I see that 30 min interval ?
Because my session is idle during the day for more then 30 min and it's not disconnected.
It's disconnect only during the night when idle for more time.
There is a setting you can modify in /etc/php.ini
this is an amount of time in seconds.
then
During the day you may have a screen open that is running ajax calls on the website which would reset the time.
session.gc_maxlifetime = 1440
then
service httpd restart
Thank you, I'll check it out
No problem, that should do it.
