Hi Team,
We are trying to import the users from AD but it showing only 50 results out of 1000 Users.
we are not able to import the Users from AD
Re: we are not able to import the Users from AD
Does the user you're logging in with when you go to import have access to all the users? Also, does the Base DN that you are using when you set up the AD server only have a subset of all the users in AD? The Base DN in the configuration is where the import starts and it can only go down the hierarchy from there. You may need to start with a higher Base DN.
