I have local backups made, and only keep 2. I've been having to go in and manually delete them every week.
Here's cmdsubsys.log showing a backup happening.
PROCESSED 0 COMMANDS
PROCESSING COMMAND ID 11510...
PROCESS COMMAND: CMD=1117, DATA=a:2:{i:0;s:19:"nagiosxi.1532885401";i:1;s:24:"/store/backups/nagiosxi/";}
CMDLINE=sudo /usr/local/nagiosxi/scripts/backup_xi.sh -n nagiosxi.1532885401 -d /store/backups/nagiosxi
No entry for terminal type "unknown";
using dumb terminal settings.
Stopping nagios: .done.
Starting nagios: done.
Backing up NagiosQL...
tar: Removing leading `/' from member names
Backing up Nagios Core...
tar: /usr/local/nagios/var/rw/nagios.qh: socket ignored
tar: /usr/local/nagios/var/ndo.sock: socket ignored
tar: /usr/local/nagios/var: file changed as we read it
Backing up Nagios XI...
PHP Warning: Invalid argument supplied for foreach() in /usr/local/nagiosxi/html/includes/components/nagiosim/nagiosim.inc.php on line 491
.....tar: /usr/local/nagiosxi/var: file changed as we read it
........Backing up MRTG...
.Backing up the SNMP trap interface configuration files...
Backing up NRDP...
...Backing up Nagvis...
.Backing up MySQL databases...
.Backing up PostgresQL databases...
Backing up cronjobs for Apache...
Backing up logrotate config files...
Backing up Apache config files...
Compressing backup...
BACKUP COMPLETE
Backup stored in /store/backups/nagiosxi/nagiosxi.1532885401.tar.gz
OUTPUT=Backup stored in /store/backups/nagiosxi/nagiosxi.1532885401.tar.gz
RETURNCODE=0
PROCESSED 1 COMMANDS
