I was looking at the following link for a similar problem.
https://support.nagios.com/forum/viewto ... =7&t=27312
Since I am adding switches but these are not ordered in a logical or human way .. I wanted to ask if someone could have ordered them
CPU
Device Fan
Power Supply
Port G1/0/1
Port G1/0/10
Port G1/0/11
Port G1/0/12
Port G1/0/2
Port G1/0/3
Port G1/0/4
Port G1/0/5
Port G1/0/6
Port G1/0/7
Port G1/0/8
Thanks..
Order column service
Re: Order column service
What we do here is simply to "prefix" single digit ports with a zero in the check output and the sorting problem is solved.
Of cause this is only possible with checks that you has written yourself or you have the possibility and skills to change the check.
Port G1/0/01
Port G1/0/02
Port G1/0/03
Port G1/0/04
Port G1/0/05
Port G1/0/06
Port G1/0/07
Port G1/0/08
Port G1/0/10
Port G1/0/11
Port G1/0/12--
D/\N
D/\N
npolovenko
- Support Tech
@danjoh, Thanks for the recommendation!
Excellent.. Thanks..!!
