got error during nagios x1 instalation
lovepreetkaul2927
I have ubuntu 16.04 LTS installed in my system. I am trying to install nagios x1 but each time i got instalation error. I can't understand why this came up.i have attached files of install.log and screenshot of terminal.
Re: got error during nagios x1 instalation
Per the official installation documentation and system requirements:
I *think* Ubuntu support is on the way?As of the time of writing, Nagios Enterprises is only able to officially provide support for installing Nagios XI on
the following Linux Distributions:
- RHEL 6.x 32-bit and 64-bit, RHEL 7.x
- RHEL requires the Optional software channel to be enabled, further details are located here:
- Enabling RHEL Optional Software Channel
- CentOS 6.x 32-bit and 64-bit, CentOS 7.x
We're looking into Ubuntu support but as of right now it is not.
I am also seeing an error during install talking about the optional rpm repo
" nagiosxi]# ./fullinstall
Nagios XI Full Installer
This script will do a complete install of Nagios XI by executing all necessary sub-scripts.
IMPORTANT: This script should only be used on a 'clean' install of CentOS, RHEL, Ubuntu LTS, Debian, or Oracle. Do NOT use this on a system that has been tasked
with other purposes or has an existing install of Nagios Core. To create such a clean install you should have selected only the base package in the OS installer.
Do you want to continue? [Y/n] y
Proceeding with installation...
Checking MySQL credentials...
MySQL not yet installed - that's okay.
Running './0-repos'...
Configuring Repos...
Passed New Subscription Check
package centos-release is not installed
An error has occurred:
ERROR: can not find RHNS CA file: /usr/share/rhn/RHN-ORG-TRUSTED-SSL-CERT
See /var/log/up2date for more information
ERROR: Please add the 'Optional' channel to your Red Hat systems subscriptions.
You can do so in the Redhat Network web interface or using the rhn-channel command.
or, install the yum-utils package and use the following command:
yum-config-manager --enable rhel-7-server-optional-rpms
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './0-repos'"
But i have the optional-rpms enabled on this server.
"yum repolist all
Loaded plugins: amazon-id, product-id, rhui-lb, search-disabled-repos, subscription-manager
This system is not registered with an entitlement server. You can use subscription-manager to register.
repo id repo name status
rhui-REGION-client-config-server-7/x86_64 Red Hat Update Infrastructure 2.0 Client Configuration Server 7 enabled: 1
rhui-REGION-rhel-server-debug-extras/7Server/x86_64 Red Hat Enterprise Linux Server 7 Extra Debug (Debug RPMs) disabled
rhui-REGION-rhel-server-debug-optional/7Server/x86_64 Red Hat Enterprise Linux Server 7 Optional Debug (Debug RPMs) disabled
rhui-REGION-rhel-server-debug-rh-common/7Server/x86_64 Red Hat Enterprise Linux Server 7 RH Common Debug (Debug RPMs) disabled
rhui-REGION-rhel-server-debug-rhscl/7Server/x86_64 Red Hat Enterprise Linux Server 7 RHSCL Debug (Debug RPMs) disabled
rhui-REGION-rhel-server-debug-supplementary/7Server/x86_64 Red Hat Enterprise Linux Server 7 Supplementary Debug (Debug RPMs) disabled
rhui-REGION-rhel-server-extras/7Server/x86_64 Red Hat Enterprise Linux Server 7 Extra(RPMs) disabled
rhui-REGION-rhel-server-optional/7Server/x86_64 Red Hat Enterprise Linux Server 7 Optional (RPMs) enabled: 15,224
rhui-REGION-rhel-server-releases/7Server/x86_64 Red Hat Enterprise Linux Server 7 (RPMs) enabled: 20,705
rhui-REGION-rhel-server-releases-debug/7Server/x86_64 Red Hat Enterprise Linux Server 7 Debug (Debug RPMs) disabled
rhui-REGION-rhel-server-releases-source/7Server/x86_64 Red Hat Enterprise Linux Server 7 (SRPMs) disabled
rhui-REGION-rhel-server-rh-common/7Server/x86_64 Red Hat Enterprise Linux Server 7 RH Common (RPMs) enabled: 233
rhui-REGION-rhel-server-rhscl/7Server/x86_64 Red Hat Enterprise Linux Server 7 RHSCL (RPMs) disabled
rhui-REGION-rhel-server-source-extras/7Server/x86_64 Red Hat Enterprise Linux Server 7 Extra (SRPMs) disabled
rhui-REGION-rhel-server-source-optional/7Server/x86_64 Red Hat Enterprise Linux Server 7 Optional (SRPMs) disabled
rhui-REGION-rhel-server-source-rh-common/7Server/x86_64 Red Hat Enterprise Linux Server 7 RH Common (SRPMs) disabled
rhui-REGION-rhel-server-source-rhscl/7Server/x86_64 Red Hat Enterprise Linux Server 7 RHSCL (SRPMs) disabled
rhui-REGION-rhel-server-source-supplementary/7Server/x86_64 Red Hat Enterprise Linux Server 7 Supplementary (SRPMs) disabled
rhui-REGION-rhel-server-supplementary/7Server/x86_64 Red Hat Enterprise Linux Server 7 Supplementary (RPMs) disabled
repolist: 36,163
RESULT=1
INSTALLATION ERROR!
"yum repolist all
repolist: 36,163
The first error was a problem with the certificate
Here's Redhat's solution
https://access.redhat.com/solutions/26435
ERROR: can not find RHNS CA file: /usr/share/rhn/RHN-ORG-TRUSTED-SSL-CERThttps://access.redhat.com/solutions/26435
