Is there any way I can check whether my other services like httpd is running on a remote VM using ncpa passive checks?
[passive checks]
%HOSTNAME%|__HOST__|120 = system/agent_version
%HOSTNAME%|Disk Usage = disk/logical/| --warning 80 --critical 90 --units Gi
%HOSTNAME%|CPU Usage = cpu/percent --warning 80 --critical 90 --aggregate avg
%HOSTNAME%|Swap Usage = memory/swap --warning 80 --critical 90 --units Gi
%HOSTNAME%|Memory Usage = memory/virtual --warning 80 --critical 90 --units Gi
%HOSTNAME%|Process Count = processes --warning 300 --critical 400
%HOSTNAME%|Process Check = processes -q 'name=httpd' -c 1:1
I tried to use the above config, but Process Count and Process Check both are giving me the same results.
Charan
How to check whether my Apache is running or not using ncpa
charangandra
charangandra
Re: How to check whether my Apache is running or not using n
I've managed to find another plugin to do this.
contents of nrdp.cfg
[passive checks]
%HOSTNAME%|__HOST__ = system/agent_version
%HOSTNAME%|Service Check|60 = services -q service=httpd,status=running
log:
2018-08-03 11:00:58,738 86474 INFO Running check: services -q service=httpd,status=running
2018-08-03 11:00:58,848 86474 INFO Message from NRDP server: OK
2018-08-03 11:00:58,849 86474 INFO Meta output from NRDP server: 1 checks processed.
However Nagios is not receiving the service perfdata and service state properly.
Nagios Configuration
use passive-service
service_description Service Check
host_name WEBSERVER
servicegroups WEB
DATATYPE::SERVICEPERFDATA TIMET::1533294186 HOSTNAME::WEBSERVER SERVICEDESC::Service Check SERVICEPERFDATA:: SERVICECHECKCOMMAND::check_dummy!0 HOSTSTATE::UP HOSTSTATETYPE::HARD SERVICESTATE::UNKNOWN SERVICESTATETYPE::HARD
Am I missing anything here?
Charan
[passive checks]
log:
use passive-service
host_name WEBSERVER
servicegroups WEB
Charan
Instead of:
Try using the following for the config:
%HOSTNAME%|Service Check|60 = services?service=httpd,status=running
