Hello, I'm using XI 5.5.0, I will upgrade shortly.
Is there a problem with changing the "localhost" name ?
Do upgrades or other functions look for "localhost" ?
Thanks for your time!
Earl
Is localhost name required?
Re: Is localhost name required?
There shouldn't be a problem with changing the "localhost" name for upgrades or any functions.
Having said that, there is a very slight chance that downloading reports as PDFs *may not* work if you change "localhost", but using the "new" name in the program and/or external URL (under System Settings) should fix the issue if ever happens. As always, try any mods in a test environment, prior to applying them in production.
Hope this helps.
Hope this helps.
- rexconsulting
I do this for all my client and my own Nagios instances. The name "localhost" loses its relevance and meaning in larger environments and in situations where you have upstream Nagios instances feeding a "Master" Nagios instance with check data via obsess/NRDP.
CP
Chris Paul
Rex Consulting, Inc
5652 Florence Terrace, Oakland, CA 94611
email: [email protected]
web: http://www.rexconsulting.net
phone, toll-free: +1 (888) 403-8996 ext 1
Chris Paul
Rex Consulting, Inc
@Bitflogger, let us know if you have any more questions.
Bitflogger
Hello, thin can be locked. Thanks!
