ERROR 1396 (HY000) at line 3: Operation CREATE USER failed for 'ndoutils'@'localhost'
I uninstalled the Nagiosxi, I uninstalled Mariadb and I deleted the directories /var/lib/mysql/nagios, /usr/local/nagios and when I ran the full installation of version 5.5.2 (I also tried previous versions) and it gave me the error that I show below, reviewing I see that only the nagios database was created but the tables were not created, so when it comes to creating the user ndoutils can not create it because there are no tables for it to do so.
What should I review to correct this problem?
Best regards...
INSTALL: POST-INSTALL: Starting NDOUtils post install...
kernel.msgmnb = 262144000
kernel.msgmax = 262144000
kernel.shmmax = 4294967295
kernel.shmall = 268435456
kernel.msgmni = 512000
NOTE: If prompted, enter the MySQL root password
ERROR: Subcomponent 'ndoutils' installation failed - exiting.
Subcomponents installation failed - exiting
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './A-subcomponents'
fraguillen
Re: ERROR 1396 (HY000) at line 3: Operation CREATE USER fail
Nagios XI installs are supported only on "clean" systems.
Having said that, we could try to recreate the issue in house, and find a workaround for you. Can you provide us with all of the commands that you used to uninstall the "old" Nagios XI server? Also, post the entire install.log file.
https://assets.nagios.com/downloads/nag ... stallationImportant: Nagios Enterprises highly recommends and will only support installing Nagios XI on a newly installed, "clean" system. Attempting to install Nagios XI on a pre-existing system with other applications already installed can cause the Nagios XI installation process to fail, critical system components and settings (e.g. database servers) to be modified in a way that negatively affects other applications, and previously installed applications to be automatically upgraded or removed. While installing XI on a system with other applications is possible, it is not recommended due to the possible interactions and complexity of multiple components that are required for Nagios XI to function. If you choose to ignore these warnings, you do so at your own risk.
