I am having a few issues with installing grafana while following the instructions listed here:
https://support.nagios.com/kb/article/nagios-xi-using-grafana-with-existing-performance-data-805.htmlCode: Select all
curl http://localhost/pnp4nagiosCode: Select all
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>401 Authorization Required</title>
</head><body>
<h1>Authorization Required</h1>
<p>This server could not verify that you
are authorized to access the document
requested. Either you supplied the wrong
credentials (e.g., bad password), or your
browser doesn't understand how to supply
the credentials required.</p>
<hr>
<address>Apache/2.2.15 (CentOS) Server at xi-c6x-x64 Port 80</address>
</body></html>Code: Select all
If you are not successful then you will need to review and fix your Apache configuration above before proceeding.
