nagios 5.5.X and PHP7
MathieuS
Post by MathieuS »
in this post: https://support.nagios.com/forum/viewto ... =6&t=48113 lmiltchev said php7 might be supported from version 5.5.X. Is this the case or is there some delay?
jomann
Development Lead
Re: nagios 5.5.X and PHP7
Post by jomann »
Nagios XI 5.5.x supports PHP 7, 7.1, and 7.2, however you need to use whatever version of PHP is available on the operating system when installing. That or the version of php that is available in the repos must be able to install when doing a "yum install php php-<module>". Were you having issues with the install?
MathieuS
Post by MathieuS »
We have a setup with an older php version and want to do a php update.
You can update PHP to 7.x on your server, then use the steps, outlined in the KB article below to install the latest SourceGuardian loaders:
https://support.nagios.com/kb/article/n ... s-816.html
I strongly recommend that you try this in test environment first, BEFORE applying it to production! Let us know if you have any more questions. Thank you!
