Nagios Core run with https and port 8443
sandeepatil
We want configure run nagios core with https and port 8443.
Need your guidance for the same.
Re: Nagios Core run with https and port 8443
This isn't a nagios question, more of an apache configuration question.sandeepatil wrote:We want configure run nagios core with https and port 8443.
Here is a guide
https://www.digicert.com/csr-ssl-instal ... penssl.htm
sandeepatil
Thanks for sharing apache related details.
We have configured SSL certificate for Nagios Core.
In Nagios XI for this port configuration, we will be edit config.inc.php.
Looking this type of solution.
You posted this in the Core forum, I am moving to Nagios XI forum, I didn't know you were using Nagios XI.
Here is our document outlining the procedure for Nagios XI
https://assets.nagios.com/downloads/nag ... s%20XI.pdf
sandeepatil
I am using Nagios XI and configured SSL as per document and Nagios XI with hhtps and port 8443 working fine.
Want to same solution for Nagios Core.
If you configured per the document, Core should already be configured.
sandeepatil
I am installed Nagios core 4.3.4.
This version having config.inc.php file as per document, but not with option for HTTPS and Port.
this is in /usr/local/nagiosxi/html/config.inc.php
there isn't any settings to change in cor's config
sandeepatil
I did this, updating change in ssl.conf.
Please close this thread.
Closingsandeepatil wrote:I did this, updating change in ssl.conf.
