Perl package error during Offline installation on Redhat 7
biancoda
Post by biancoda »
I'm trying to install Nagios XI on a new RedHat 7 Offline.
I have downloaded the tarfile nagiosxi-5.5.2-1.el7.x86_64.tar.gz and run the fullinstall
I have installed all the packages, but I'm getting an error with the perl modules.
Error: Package: nagiosxi-5.5.2-1.el7.x86_64 (/nagiosxi-5.5.2-1.el7.x86_64)
           Requires: perl(XML::Simple)
Error: Package: perl-Config-IniFiles-2.79-1.el7.noarch (/perl-Config-IniFiles-2.79-1.el7.noarch)
           Requires: perl(IO::Scalar) >= 2.109
Error: Package: perl-Net-SNMP-6.0.1-7.el7.noarch (/perl-Net-SNMP-6.0.1-7.el7.noarch)
           Requires: perl(Digest::SHA1)
Error: Package: perl-Nagios-Monitoring-Plugin-0.51-1.el7.noarch (/perl-Nagios-Monitoring-Plugin-0.51-1.el7.noarch)
           Requires: perl(Config::Tiny)
           Requires: perl(XML::Parser)
           Requires: perl(Crypt::SSLeay)
 You could try using --skip-broken to work around the problem
 You could try running: rpm -Va --nofiles --nodigest
I don't want to use --skip-broken, because I know the modules are there.
[root@nagios01 nagiosxi]# cpan -l | grep XML::Simple
XML::Simple     2.25
[root@nagios01 nagiosxi]# cpan -l | grep IO::Scalar
Test::Builder::IO::Scalar       2.114
IO::ScalarArray 2.111
IO::Scalar      2.111
Test::Builder::IO::Scalar       2.110
vendor_perl::Test::Builder::IO::Scalar  2.110
[root@nagios01 nagiosxi]# cpan -l | grep Digest::SHA1
Digest::SHA1    2.13
Crypt::Digest::SHA1     0.061
[root@nagios01 nagiosxi]# cpan -l | grep Config::Tiny
Config::Tiny    2.23
[root@nagios01 nagiosxi]# cpan -l | grep XML::Parser
XML::Parser     2.44
XML::Parser::Expat      2.44
XML::Parser::Style::Tree        undef
XML::Parser::Style::Subs        undef
XML::Parser::Style::Objects     undef
XML::Parser::Style::Debug       undef
XML::Parser::Style::Stream      undef
[root@nagios01 nagiosxi]# cpan -l | grep -i Crypt::SSLeay
Crypt::SSLeay   0.72
Crypt::SSLeay::MainContext      undef
Crypt::SSLeay::Conn     undef
Crypt::SSLeay::Version  undef
Crypt::SSLeay::X509     undef
Crypt::SSLeay::CTX      undef
Crypt::SSLeay::Err      undef
Any idea what I'm doing wrong?
thanks,
Daniel
Re: Perl package error during Offline installation on Redhat
The installer is looking to get these from the yum repositories, not cpan.
per the instructions here you are going to need to get these from the yum optional channel
https://repo.nagios.com/?repo=offline#install
RHEL
Offline server must still have access to RHEL Base & Optional Channel Repo (actual or clone) for installation/upgrade
dejavu-lgc-sans-fonts.noarch
dejavu-lgc-sans-mono-fonts.noarch
graphviz-gd.x86_64
perl-Crypt-DES.x86_64
perl-Parse-RecDescent.noarch
php-mbstring.x86_64
php-snmp.x86_64
biancoda
Post by biancoda »
I have installed the packaged for the optional channel.
But after a few hours of installing the perl modules manually, I end up installing them using the rpm.
So basically it needs the package.
biancoda wrote:I have installed the packaged for the optional channel.
correct
