The bandwidth performance graph function in our NagiosXI server is not working. It is not showing any data. Request assistance in fixing this issue.
I can private message our system profile and any other files if requested. We are running build 5.5.2
Thank you for your time.
issue with bandwidth performance graphs
Re: issue with bandwidth performance graphs
Have you tried troubleshooting your issue by following ALL of the steps, outlined in our KB article on the topic?
https://support.nagios.com/kb/article/n ... hs-29.html
We went thru the article but are still getting lots of errors in the log file and the graphing is still not working. I can PM a log file if requested. Below are the main errors in the log.
WARNING: Expected a number but got 'noSuchInstance'
also
did not eval into defined data
also
Please PM one of us a copy of your profile, you can download it from Admin > System Profile > Download Profile.
You have a ton of mrtg files, please follow the "MRTG Running Longer Than Five Minutes" section from this KB article and send me the ENTIRE output of the command once it's finished so that I can review it:
