Nagiosxi webpage keeps crashing
airforcemiller
Post by airforcemiller »
I just downloaded the latest ova for ESXi for nagiosxi. It deployed successfully, but I keep running int an issue where the webpage keeps crashing when I try and do the install and once the install happens. What logs / where can I get info to help understand what is going on and stop the crashes from happening. It seems that this is a regular occurrence every few min when I am in nagiosxi.
npolovenko
Re: Nagiosxi webpage keeps crashing
Post by npolovenko »
Hello, @airforcemiller. I'd start by looking at the apache error log. Run the following command in the console:
tail -f /var/log/https/error_log
And while it's running try to access the web page a few times, and when it crashes you should see some errors in the console.
airforcemiller
npolovenko wrote:Hello, @airforcemiller. I'd start by looking at the apache error log. Run the following command in the console:
@npolovenko
I believe it has stabilized, I was tinkering around with the ESXi Networks. Once I put Nagios on the other virtual network it stopped crashing all together and has been holding strong for a while now. I appreciate the location of where to look if I start having more errors. Slowly wrapping my head around Nagios
airforcemiller wrote:I believe it has stabilized, I was tinkering around with the ESXi Networks. Once I put Nagios on the other virtual network it stopped crashing all together and has been holding strong for a while now. I appreciate the location of where to look if I start having more errors. Slowly wrapping my head around Nagios
Great let us know if we can be of further assistance
