xi_sessions does not exist Error After Upgrade to 5.5.2
ariawenda
Post by ariawenda »
We recently upgraded the server to version 5.5.2 from the version xi-2014r1.0. There are 2 servers that we upgraded, one of them has the web GUI returning an error of xi_sessions does not exist:
refer to attachment.
The other server seems to be working fine. Any pointer on how we can resolve this?
jomann
Development Lead
Re: xi_sessions does not exist Error After Upgrade to 5.5.2
Post by jomann »
I would verify that all the new XI 5.5 tables have been created. You should save the below SQL into a file and then import it into your nagiosxi database - is your XI using postgresql or mysql?
CREATE TABLE IF NOT EXISTS `nagiosxi`.`xi_auth_tokens` (
    `auth_token_id` int auto_increment,
    `auth_user_id` int not null,
    `auth_session_id` int not null,
    `auth_token` varchar(128),
    `auth_valid_until` datetime,
    `auth_expires_at` datetime,
    `auth_restrictions` mediumtext,
    `auth_used` smallint default 0 not null,
    primary key (`auth_token_id`),
    unique (`auth_token_id`)
) ENGINE=InnoDB DEFAULT CHARSET=utf8 AUTO_INCREMENT=1;
CREATE TABLE IF NOT EXISTS `nagiosxi`.`xi_sessions` (
    `session_id` int auto_increment,
    `session_phpid` varchar(128),
    `session_created` datetime,
    `session_user_id` int not null,
    `session_address` varchar(128),
    `session_page` varchar(255),
    `session_data` text,
    `session_last_active` timestamp NOT NULL DEFAULT current_timestamp ON UPDATE current_timestamp,
    primary key (`session_id`),
    unique (`session_id`)
CREATE TABLE IF NOT EXISTS `nagiosxi`.`xi_cmp_trapdata` (
    `trapdata_id` int auto_increment,
    `trapdata_updated` timestamp NOT NULL DEFAULT current_timestamp ON UPDATE current_timestamp,
    `trapdata_enabled` smallint default 1,
    `trapdata_event_name` varchar(128) NOT NULL default '',
    `trapdata_event_oid` varchar(256) NOT NULL default '',
    `trapdata_category` varchar(128) NOT NULL default '',
    `trapdata_severity` varchar(64) NOT NULL default '',
    `trapdata_custom_format` text,
    `trapdata_raw_data` text,
    `trapdata_exec` text,
    `trapdata_desc` text,
    `trapdata_wizard_integration_enabled` smallint default 0,
    `trapdata_wizard_integration_data` text,
    primary key (`trapdata_id`),
    unique (`trapdata_event_name`)
CREATE TABLE IF NOT EXISTS `nagiosxi`.`xi_cmp_trapdata_log` (
    `trapdata_log_id` int auto_increment,
    `trapdata_log_event_name` varchar(128) NOT NULL default '',
    `trapdata_log_event_oid` varchar(50) NOT NULL default '',
    `trapdata_log_numeric_oid` varchar(100),
    `trapdata_log_symbolic_oid` varchar(100),
    `trapdata_log_community` varchar(20),
    `trapdata_log_trap_hostname` varchar(100),
    `trapdata_log_trap_ip` varchar(16),
    `trapdata_log_agent_hostname` varchar(100),
    `trapdata_log_agent_IP` varchar(16),
    `trapdata_log_category` varchar(20) NOT NULL default '',
    `trapdata_log_severity` varchar(20) NOT NULL default '',
    `trapdata_log_uptime` varchar(20) NOT NULL default '',
    `trapdata_log_datetime` datetime,
    `trapdata_log_bindings` text,
    primary key (`trapdata_log_id`),
    unique (`trapdata_log_id`)
ariawenda
Post by ariawenda »
@jomann: Thank you for your prompt reply. It seems to be able to resolve the issue.
Now we are facing a new issue of Monitoring Engine failed to start. Screenshot attached.
We tried to stop and start it again but it's still reporting as not running.
ssax
Dreams In Code
Post by ssax »
Please run this command:
service nagios restart
Then look in your /var/log/messages and your /usr/local/nagios/var/nagios.log and post any relevant errors/messages.
ariawenda
Post by ariawenda »
For the moment, the service restart seems to work. Thank you very much for your quick response.
We can consider this as solved then.
ssax
Dreams In Code
Post by ssax »
Did the upgrade fail in the middle? Were you able to re-run the upgrade successfully?
