Problemes after to upgrade to Nagios XI 5.5.2
morabanc
Post by morabanc »
We have upgrade Nagios to 5.5.2. Since then we're experiencing some issues related to acknolwledge and force check. Problem is not solved restarting nagios process, only restarting the server. A possible clue, when executing /etc/init.d/nagios status, the aswer is nagios is not running, but nagios is running.
Thanks.
Re: Problemes after to upgrade to Nagios XI 5.5.2
Can you show the output of the following:
grep ^NagiosRunFile /etc/init.d/nagios
grep lock_file /usr/local/nagios/etc/nagios.cfg
morabanc
Re: Problems after to upgrade to Nagios XI 5.5.2
Post by morabanc »
Here the results:
NagiosRunFile=/var/run/nagios.lock
lock_file=/usr/local/nagios/var/nagios.lock
Lets edit /etc/init.d/nagios
change this
to this
NagiosRunFile=/usr/local/nagios/var/nagios.lock
the run the following
service nagios stop
killall -9 nagios
rm -f /usr/local/nagios/var/nagios.lock /var/run/nagios.lock
service nagios start
morabanc
Post by morabanc »
I've just run the commands, still the same error. I'm seeing this message at nagios.log
[1534252215] Failed to obtain lock on file /usr/local/nagios/var/nagios.lock: Permission denied
[1534252215] Bailing out due to errors encountered while attempting to daemonize... (PID=19920)
please post the output of the following
ls -al /usr/local/nagios/var/
morabanc
Post by morabanc »
I seeems there are some problem with permissions, If I apply configuration via the CCM the nagios.lock belons to root user:
ls -l /usr/local/nagios/var/nagios.lock
-rw-r--r-- 1 root root 0 Aug 14 15:26 /usr/local/nagios/var/nagios.lock
I must restart nagios via with nagio user and the nagios.lock take the right permissions:
su nagios
/etc/init.d/nagios restart
Stopping nagios: No lock file found in /usr/local/nagios/var/nagios.lock
Starting nagios: done.
exit
-rw-r--r-- 1 nagios users 6 Aug 14 15:29 /usr/local/nagios/var/nagios.lock
morabanc
Post by morabanc »
Sorry! I didn't saw your post:
total 77136
drwxrwxr-x 6 nagios nagios 12288 Aug 14 15:30 .
drwxr-xr-x 9 root root 4096 Jul 3 2014 ..
drwxrwxr-x 2 nagios nagios 73728 Aug 14 15:05 archives
-rw-r----- 1 apache apache 0 Jul 6 2014 graphapi.log
-rw-r----- 1 apache apache 445006 Aug 11 2012 graphapi.log-20120812
-rw-r----- 1 apache apache 107843 Oct 25 2012 graphapi.log-20121028
-rw-r----- 1 apache apache 860 Jun 29 2014 graphapi.log-20140629.gz
-rw-r----- 1 apache apache 659 Jul 6 2014 graphapi.log-20140706.gz
-rw-r--r-- 1 nagios users 60447 Aug 14 15:30 host-perfdata
-rw-r--r-- 1 nagios users 6 Aug 14 15:29 nagios.lock
-rw-r--r-- 1 nagios nagios 11890314 Aug 14 15:30 nagios.log
-rw-r--r-- 1 nagios nagios 88827 Aug 5 03:26 nagios.log-20180805.gz
-rw-r--r-- 1 nagios nagios 85307 Aug 12 03:20 nagios.log-20180812.gz
-rw-rw-r-- 1 nagios users 5166277 Dec 15 2014 nagios.tmp0iE6YI
-rw------- 1 nagios users 2916352 Feb 7 2018 nagios.tmp1pjibf
-rw------- 1 nagios nagios 4834932 Nov 4 2014 nagios.tmp7InaiE
-rw------- 1 nagios users 0 Jan 27 2014 nagios.tmpa1rpF8
-rw-rw-r-- 1 nagios users 7295992 Apr 10 2017 nagios.tmpjpFvEE
-rw------- 1 nagios nagios 4781459 Sep 23 2014 nagios.tmpKxOJgF
-rw------- 1 nagios nagios 0 Jan 25 2016 nagios.tmpopWaml
-rw------- 1 nagios nagios 4097 Jul 28 2014 nagios.tmpSjuFZw
-rw------- 1 nagios users 409600 Oct 1 2015 nagios.tmptfzqJx
-rw-rw-r-- 1 nagios users 5137620 Dec 10 2014 nagios.tmpwhfx3F
-rw-r----- 1 nagios nagios 5 Aug 13 18:46 ndo2db.lock
-rw-r--r-- 1 nagios nagcmd 0 Aug 14 15:26 ndomod.tmp
srwxr-x--- 1 nagios nagios 0 Aug 13 18:46 ndo.sock
-rw-r--r-- 1 nagios nagios 62222 Aug 14 15:24 npcd.log
-rw-r--r-- 1 nagios nagios 27422 Oct 27 2012 npcd.log-20121028
-rw-r--r-- 1 nagios nagios 10437 Aug 5 03:26 npcd.log-20180805.gz
-rw-r--r-- 1 nagios nagios 10219 Aug 12 03:20 npcd.log-20180812.gz
-rw-r----- 1 root root 5 Aug 13 18:46 nrpe.pid
-rw-r--r-- 1 nagios nagios 4704426 Aug 14 15:29 objects.cache
-rw-r--r-- 1 nagios nagios 4704426 Aug 14 15:29 objects.precache
-rw-rw-rw- 1 nagios nagios 127319 Aug 14 15:24 perfdata.log
-rw-rw-rw- 1 nagios nagios 507798 Aug 12 2012 perfdata.log-20120812
-rw-rw-rw- 1 nagios nagios 52930 Oct 27 2012 perfdata.log-20121028
-rw-rw-rw- 1 nagios nagios 48808 Aug 5 03:26 perfdata.log-20180805.gz
-rw-rw-rw- 1 nagios nagios 48478 Aug 12 03:20 perfdata.log-20180812.gz
-rw------- 1 nagios users 7303902 Aug 14 15:29 retention.dat
drwxrwsrwx 2 nagios nagcmd 4096 Aug 14 15:29 rw
---------- 1 nagios users 0 Sep 19 2014 sed00PEC6
---------- 1 nagios users 0 Jun 7 2015 sed0bcBZa
---------- 1 nagios users 0 Dec 27 2014 sed0bQfeS
-rw-r--r-- 1 nagios users 599912 May 6 2016 sed0BqSEL
---------- 1 nagios users 0 Nov 8 2014 sed0HFp9e
---------- 1 nagios users 0 Oct 2 2014 sed13jzij
---------- 1 nagios users 0 Jul 30 2014 sed19IaKm
---------- 1 nagios users 0 Dec 10 2016 sed1KoFRQ
---------- 1 nagios users 0 Apr 1 2016 sed1l1nGP
---------- 1 nagios users 0 Nov 4 2014 sed1NIF2I
---------- 1 nagios users 0 Jul 12 2015 sed1NXZZW
---------- 1 nagios users 0 Apr 10 2016 sed27olmg
---------- 1 nagios users 0 Apr 27 2016 sed2gZAvb
---------- 1 nagios users 0 Nov 7 2014 sed2KHzCF
---------- 1 nagios users 0 Feb 2 2016 sed2OQR7w
---------- 1 nagios users 0 Nov 22 2014 sed2PsFVg
---------- 1 nagios users 0 Apr 22 2016 sed2zfGIb
---------- 1 nagios users 0 Jun 13 2016 sed3A8t9Q
---------- 1 nagios users 0 Mar 28 2016 sed3FfdxO
---------- 1 nagios users 0 Dec 21 2016 sed3GFwnP
---------- 1 nagios users 0 Nov 5 2014 sed3qVq6I
---------- 1 nagios users 49277 Oct 24 2014 sed3TPFoh
---------- 1 nagios users 0 Oct 29 2014 sed3TWASj
-rw-r--r-- 1 nagios users 677926 Mar 19 2016 sed3U4yes
---------- 1 nagios users 0 Oct 4 2014 sed3y3wtq
---------- 1 nagios users 0 Sep 30 2014 sed4IaTDN
---------- 1 nagios users 0 Mar 10 2015 sed4ndJMn
---------- 1 nagios users 0 Oct 2 2014 sed4UiBSj
---------- 1 nagios users 0 Oct 13 2014 sed4Y2XAh
---------- 1 nagios nagios 0 Nov 9 2014 sed53RybM
---------- 1 nagios users 0 Jan 27 2016 sed5C0wnV
---------- 1 nagios users 0 Nov 17 2014 sed5doO9k
---------- 1 nagios users 0 Oct 24 2014 sed5NE8xe
---------- 1 nagios users 0 Mar 4 2015 sed5WOjv8
---------- 1 nagios users 0 Apr 27 2016 sed6JrdSR
---------- 1 nagios users 0 Oct 14 2014 sed7SFZXI
---------- 1 nagios users 0 May 11 2016 sed7xOWoX
---------- 1 nagios nagios 0 Dec 6 2015 sed81t3nT
---------- 1 nagios users 0 Jul 11 2015 sed8DhvSN
---------- 1 nagios users 0 Jan 7 2016 sed8eaftk
---------- 1 nagios users 0 Jul 17 2014 sed8ptFTo
---------- 1 nagios users 0 Nov 14 2014 sed95C34R
---------- 1 nagios users 0 Feb 19 2016 sed9ApiUC
---------- 1 nagios users 245471 Apr 10 2016 sed9MLDXT
---------- 1 nagios users 0 Mar 31 2016 sedAfFGVl
---------- 1 nagios users 0 Jun 14 2015 sedAGkEFu
---------- 1 nagios nagios 0 Oct 21 2014 sedaJ2FMX
---------- 1 nagios users 0 Mar 3 2016 sedAKBerU
---------- 1 nagios users 0 Jan 30 2016 sedaPpHRr
---------- 1 nagios users 0 Oct 24 2014 sedareln0
---------- 1 nagios users 0 May 4 2016 sedaxvSOA
---------- 1 nagios users 0 Jan 1 2016 sedaZ79Iq
---------- 1 nagios users 0 Dec 13 2015 sedB3W0xu
---------- 1 nagios nagios 0 Oct 24 2014 sedBI7pCq
---------- 1 nagios users 0 Mar 19 2016 sedBIJCFO
---------- 1 nagios users 0 Jun 6 2016 sedbTfpt5
---------- 1 nagios users 0 Jul 12 2015 sedBY5Sv6
---------- 1 nagios users 0 Apr 27 2016 sedbYpUiK
---------- 1 nagios users 0 Jun 10 2016 sedc7AukG
---------- 1 nagios users 0 Feb 19 2016 sedCCzmc2
---------- 1 nagios users 0 Nov 13 2014 sedcjB0BL
---------- 1 nagios users 0 Feb 10 2018 sedCOFOmh
---------- 1 nagios users 0 Oct 11 2014 sedConmBC
---------- 1 nagios users 0 Jun 7 2015 sedCzpNaf
---------- 1 nagios users 0 Jul 25 2014 sedD2yo97
---------- 1 nagios users 0 Jul 5 2015 sedDAt28Z
---------- 1 nagios users 0 Jan 8 2017 seddhpvkl
---------- 1 nagios users 0 Nov 13 2015 seddIkvtn
---------- 1 nagios users 295 Apr 28 2016 seddYw2mG
---------- 1 nagios users 127182 Jun 13 2017 sedE0bVsH
---------- 1 nagios users 0 May 5 2016 sedEday8t
-rw-r--r-- 1 nagios users 62953 Oct 22 2015 sedEHESTq
---------- 1 nagios users 0 Apr 19 2016 sedel5Sfg
---------- 1 nagios users 0 Dec 12 2015 sedeYoxKj
---------- 1 nagios users 0 Dec 9 2017 sedf6CejV
---------- 1 nagios users 0 Mar 31 2016 sedfaiy9z
-rw-r--r-- 1 nagios users 457651 Nov 6 2014 sedfD1cuR
---------- 1 nagios users 0 Feb 2 2016 sedFEjeTh
---------- 1 nagios users 0 Nov 6 2014 sedFHVtw2
---------- 1 nagios users 0 Feb 19 2016 sedFJDGEG
---------- 1 nagios users 0 Dec 14 2015 sedFjjx3W
---------- 1 nagios users 0 Jan 30 2016 sedfLtVmJ
---------- 1 nagios users 0 Apr 1 2016 sedGaOAFo
---------- 1 nagios users 0 May 20 2016 sedgJwOIN
---------- 1 nagios nagios 119234 Jul 28 2014 sedGn9Ap2
---------- 1 nagios users 0 Apr 21 2016 sedgU5yWO
---------- 1 nagios users 0 Dec 13 2015 sedheSjDm
---------- 1 nagios users 0 Nov 1 2014 sedhIOY7z
---------- 1 nagios users 0 Dec 27 2017 sedHouwIT
---------- 1 nagios users 0 Oct 1 2014 sedHUhszu
---------- 1 nagios users 0 Jul 1 13:31 sedI0hCB1
---------- 1 nagios users 0 Jun 14 2015 sedIF8tAr
---------- 1 nagios users 0 Dec 20 2015 sedIgiLXX
-rw-r--r-- 1 nagios users 606432 Oct 20 2014 sedihNtCE
---------- 1 nagios users 0 Nov 21 2014 sedIlTkdV
---------- 1 nagios users 0 Nov 22 2014 sedim50Vp
---------- 1 nagios users 450780 Feb 19 2016 sedIWtT7M
---------- 1 nagios users 0 Mar 19 2016 sedJEcEY6
-rw-r--r-- 1 nagios nagios 698233 Apr 14 2016 sedJHTDsd
---------- 1 nagios users 0 Mar 15 2015 sedjLedLF
---------- 1 nagios users 0 May 22 2016 sedJLW9lK
---------- 1 nagios users 0 Nov 19 2014 sedJQht83
---------- 1 nagios users 0 Oct 10 2014 sedJrGBC3
---------- 1 nagios users 0 Sep 30 2014 sedJrVpjI
---------- 1 nagios users 59145 Jun 8 2016 sedJTbwbw
---------- 1 nagios users 0 Apr 30 2016 sedJZrKBO
---------- 1 nagios users 0 Nov 26 2017 sedK1rD8w
---------- 1 nagios users 355 Apr 29 2016 sedKB6VvD
---------- 1 nagios users 0 Oct 15 2016 sedKEiXUP
---------- 1 nagios users 0 Jun 12 2015 sedKhdtRE
---------- 1 nagios users 0 Nov 1 2014 sedKiwC0P
---------- 1 nagios users 0 Jun 6 2016 sedkjJchR
---------- 1 nagios users 0 Dec 27 2015 sedkK6Who
---------- 1 nagios users 49240 Oct 10 2014 sedKkrJDx
---------- 1 nagios users 0 Apr 1 2016 sedkmL6hG
---------- 1 nagios users 20305 Oct 20 2014 sedkp64cM
---------- 1 nagios users 0 Mar 19 2016 sedKrxjdb
---------- 1 nagios users 0 Apr 23 2016 sedkwKTXj
---------- 1 nagios users 0 Feb 17 2016 sedkYrZOU
---------- 1 nagios nagios 0 Oct 27 2014 sedL1F8uH
---------- 1 nagios users 0 Apr 2 2016 sedl1IVaO
---------- 1 nagios users 0 May 4 2016 sedlde35D
---------- 1 nagios users 0 Mar 19 2016 sedLMBoqC
---------- 1 nagios users 0 Mar 26 2016 sedlQMErW
---------- 1 nagios users 0 Oct 16 2014 sedLQY6OB
---------- 1 nagios users 0 Sep 30 2014 sedLTRkqr
---------- 1 nagios users 16618 Apr 1 2016 sedlTsAoN
---------- 1 nagios users 0 Jan 18 2015 sedlTx0Om
---------- 1 nagios users 0 Mar 29 2016 sedLwGDLW
---------- 1 nagios users 0 Dec 5 2014 sedlXLVuQ
-rw-r--r-- 1 nagios users 0 Nov 4 2014 sedma9c42
-rw-r--r-- 1 nagios users 353555 Mar 31 2016 sedmeS3CV
---------- 1 nagios users 0 Sep 20 2014 sedmffRiD
---------- 1 nagios users 0 May 11 2016 sedmIPb5F
---------- 1 nagios users 0 Oct 29 2014 sedMoR6QC
---------- 1 nagios users 0 Sep 11 2014 sedmQvs6Q
---------- 1 nagios users 0 Dec 20 2015 sedMvfJtI
---------- 1 nagios users 0 Mar 2 2016 sedMzDRXn
---------- 1 nagios users 0 Sep 23 2014 sedN6I7dP
---------- 1 nagios users 0 Jul 28 2014 sedND9Xrr
---------- 1 nagios users 0 Sep 22 2015 sednEAD1r
---------- 1 nagios users 0 Oct 29 2015 sedngV5jR
---------- 1 nagios users 0 Nov 14 2014 sedNiLX5d
---------- 1 nagios users 0 Mar 22 2016 sednMsAZ5
---------- 1 nagios users 0 Nov 6 2014 sednNXSNh
---------- 1 nagios users 0 Jan 17 2016 sedNOGQqG
---------- 1 nagios users 0 Sep 30 2014 sedNtEh9f
---------- 1 nagios users 0 Nov 18 2017 sednYcvMK
---------- 1 nagios users 0 Mar 31 2016 sedNZHvsk
---------- 1 nagios users 0 Feb 7 2016 sedoa1cm6
---------- 1 nagios users 0 May 26 2016 sedoA5RKr
---------- 1 nagios users 0 Mar 31 2016 sedOHQEg3
---------- 1 nagios users 0 Oct 24 2015 sedoKIT4R
---------- 1 nagios users 0 Sep 17 2014 sedOSKuk4
---------- 1 nagios users 0 Apr 24 2016 sedoVQUAA
---------- 1 nagios users 0 Jan 24 2016 sedozBkFN
---------- 1 nagios users 4511 Apr 21 06:10 sedOZDMAJ
---------- 1 nagios users 0 Feb 10 2016 sedP2JLGx
---------- 1 nagios users 0 Oct 2 2014 sedPbvYVf
---------- 1 nagios users 0 Apr 21 07:12 sedpDtG3X
---------- 1 nagios users 0 Nov 22 2014 sedpFHSta
---------- 1 nagios users 0 Oct 29 2015 sedpKxSzR
---------- 1 nagios users 0 Dec 4 2014 sedPnEhh3
---------- 1 nagios users 0 May 29 2016 sedpNz71k
---------- 1 nagios users 0 Sep 30 2014 sedPtGfuq
---------- 1 nagios users 114476 Mar 31 2016 sedpURYNS
---------- 1 nagios users 0 Mar 30 2015 sedq0qwFz
---------- 1 nagios users 0 Mar 27 2016 sedQ6aLCq
---------- 1 nagios users 0 Aug 2 2015 sedqiRVXd
---------- 1 nagios users 33406 Oct 15 2014 sedqLFMFL
---------- 1 nagios users 0 Nov 8 2014 sedqQfAZU
---------- 1 nagios users 0 Oct 20 2014 sedqSpJaR
---------- 1 nagios users 113966 Oct 15 2014 sedqyslpR
---------- 1 nagios users 0 Sep 30 2014 sedR6ovsZ
---------- 1 nagios users 0 Mar 31 2016 sedrcF2CM
---------- 1 nagios users 0 Nov 4 2014 sedrEYQOx
---------- 1 nagios users 0 Dec 10 2014 sedRmiUeM
---------- 1 nagios users 0 May 22 2016 sedRMmZLi
---------- 1 nagios users 1425208 Nov 30 2014 sedrQr1wo
---------- 1 nagios users 0 Mar 3 2016 sedrvisPV
---------- 1 nagios users 16654 Oct 20 2014 sedrVR7VS
---------- 1 nagios users 0 Oct 22 2014 sedrX6NTk
---------- 1 nagios users 0 Sep 30 2014 sedsC8yrJ
---------- 1 nagios users 0 Jan 24 2016 sedskTNW0
---------- 1 nagios users 0 Aug 2 2015 sedSwfE9l
---------- 1 nagios users 0 Oct 20 2014 sedszsEHz
---------- 1 nagios users 0 Dec 27 2015 sedt9SPQ8
---------- 1 nagios users 0 Sep 3 2014 sedTeHbw6
---------- 1 nagios users 15976 Sep 17 2014 sedtglJOu
---------- 1 nagios users 0 Mar 31 2016 sedtiEylK
---------- 1 nagios users 16638 Nov 29 2014 sedToUnB1
---------- 1 nagios nagios 0 Dec 6 2015 sedtp7391
---------- 1 nagios users 0 Apr 15 2016 sedtqIuta
-rw-r--r-- 1 nagios users 155125 Nov 13 2014 sedu1IbW5
---------- 1 nagios users 0 Jun 10 2016 sedU2EXO8
---------- 1 nagios nagios 0 Aug 1 2014 sedU9pnsV
---------- 1 nagios users 0 Mar 14 2015 sedub9eaT
---------- 1 nagios nagios 16057 Apr 14 2016 seduEzFq2
---------- 1 nagios users 0 Oct 10 2014 seduqe8lJ
---------- 1 nagios users 823348 Mar 19 2016 sedUr7OPK
---------- 1 nagios users 0 Oct 24 2014 sedURLzp4
---------- 1 nagios nagios 0 Oct 1 2014 sedUUfW1s
---------- 1 nagios users 0 Jul 5 2015 seduxrYiT
---------- 1 nagios users 16583 Oct 15 2014 sedV4q9oL
---------- 1 nagios users 0 Feb 17 2016 sedv8Ia9J
---------- 1 nagios users 0 Jan 3 2016 sedvd3oYm
---------- 1 nagios users 0 Mar 29 2015 sedvFngx5
---------- 1 nagios nagios 0 Oct 25 2014 sedvmgSfv
---------- 1 nagios users 1130555 Mar 23 2016 sedvsKBxE
---------- 1 nagios users 0 Sep 7 2015 sedwHOEDK
---------- 1 nagios users 0 Jun 14 2016 sedWlWDwy
---------- 1 nagios users 0 Nov 7 2014 sedwPXuxA
---------- 1 nagios users 0 Oct 10 2014 sedwWeAIZ
---------- 1 nagios users 0 Jan 1 2016 sedx1Nqwz
---------- 1 nagios users 0 Oct 2 2014 sedx2juWg
---------- 1 nagios users 0 Mar 31 2016 sedx3K50U
---------- 1 nagios users 0 Dec 10 2015 sedX3VPTk
---------- 1 nagios users 0 Oct 11 2014 sedx8q702
---------- 1 nagios users 0 Jul 22 2016 sedxemAMo
---------- 1 nagios users 0 Sep 20 2014 sedXgtW1K
---------- 1 nagios users 0 Apr 24 2016 sedXIK7LB
---------- 1 nagios users 0 Apr 30 2016 sedXPcw7p
---------- 1 nagios users 0 Mar 3 2016 sedXRpdPx
---------- 1 nagios users 16304 Oct 2 2014 sedxUcpbN
---------- 1 nagios users 0 Jul 23 2016 sedy3ePC1
---------- 1 nagios users 0 Jan 12 2017 sedyD8YRc
---------- 1 nagios users 20572 Feb 17 2016 sedYDLplx
---------- 1 nagios users 0 Oct 1 2014 sedYPfkVE
---------- 1 nagios users 0 Mar 16 2015 sedzMv5IM
---------- 1 nagios users 0 Jan 3 2016 sedZrn6uZ
---------- 1 nagios users 0 Nov 6 2014 sedZTCxYI
---------- 1 nagios users 1556813 Oct 1 2014 sedZXUzAm
-rw-r--r-- 1 nagios users 502619 Aug 14 15:30 service-perfdata
drwxr-xr-x 5 nagios nagios 4096 Jun 18 2012 spool
drwxr-xr-x 2 nagios nagios 4096 Aug 14 15:29 stats
-rw-rw-r-- 1 nagios users 7299752 Aug 14 15:30 status.dat
run
chown nagios.nagios /usr/local/nagios/var/
then restart nagios
morabanc
Post by morabanc »
Same behaviour, when restarting nagios via cli (with root user) or via CCM nagio.lock belongs to root:
[root@nagiosxi rari01c]# /etc/init.d/nagios restart
Stopping nagios: .done.
[root@nagiosxi rari01c]# ls -l /usr/local/nagios/var/nagios.lock
-rw-r--r-- 1 root root 0 Aug 14 15:57 /usr/local/nagios/var/nagios.lock
