NXLog Issue?
CameronWP
NXLog Issue?
Post by CameronWP »
Hi:
I am struggling to get terminal server events into Log Server because it seems NXLog isn't parsing the messages as expected. It appears anything with a IPv6 address in the message body is throwing an error. Here is an example:
{"EventTime":"2018-08-14 14:40:30","Hostname":"server.domain.ca","Keywords":1152921504606846976,"EventType":"INFO","SeverityValue":2,"Severity":"INFO","EventID":21,"SourceName":"Microsoft-Windows-TerminalServices-LocalSessionManager","ProviderGuid":"{5D896912-022D-40AA-A3A8-4FA5515C76D7}","Version":0,"Task":0,"OpcodeValue":0,"RecordNumber":43149,"ActivityID":"{F420F181-1449-4944-B6A9-3CF4D9FA0000}","ProcessID":908,"ThreadID":1688,"Channel":"Microsoft-Windows-TerminalServices-LocalSessionManager/Operational","Domain":"NT AUTHORITY","AccountName":"SYSTEM","UserID":"S-1-5-18","AccountType":"User","ERROR_EVT_UNRESOLVED":true,"Opcode":"Info","EventReceivedTime":"2018-08-14 14:40:31","SourceModuleName":"eventlog","SourceModuleType":"im_msvistalog","message":null}
I have attached the corresponding event. If the Source IP is V4 it works fine but any event with the IPv6 containing the percent sign doesn't work. I have tried adding replace statements in the NXLog config to no avail. Any help would be appreciated!
cdienger
Re: NXLog Issue?
Post by cdienger »
What version of nxlog are you using? This sounds like an issue with nxlog and it may be fixed in newer versions: https://nxlog.co/products/nxlog-communi ... n/download
CameronWP
Re: NXLog Issue?
Post by CameronWP »
cdienger wrote:What version of nxlog are you using? This sounds like an issue with nxlog and it may be fixed in newer versions: https://nxlog.co/products/nxlog-communi ... n/download
That was my thought as well so I updated to the latest and I am still seeing the issue. Can you recommend an alternative to nxlog?
cdienger
Re: NXLog Issue?
Post by cdienger »
I don't have direct experience with much else, but I know some people use syslog agents on their Windows machines.
Re: NXLog Issue?
Post by mcapra »
I'm almost certain there's some clever things you could do with im_exec to work around this particular problem, but that's getting pretty into the weeds with nxlog. Something to the effect of "if using im_msvistalog, and ERROR_EVT_UNRESOLVED=true, run powershell to find eventlog record by EventReceivedTime, EventID, ProcessID, and ThreadID then overwrite the original event". I'm pretty sure this is strictly a bug in nxlog; I cannot find anything on the MSDN that says you shouldn't put % signs in your EventLog records.
syslog-ng is a very viable alternative for windows If you're comfortable building your own binaries.
cdienger
Re: NXLog Issue?
Post by cdienger »
Thanks for the input, @mcapra!
