localhost/Service Status - ndo2db is UNKNOWN [Solved]
abiswas
Post by abiswas »
We started having an error with one of ndo2db service for couple days now.
Nagios has detected a problem with this service.
Notification Type: PROBLEM
Service: Service Status - ndo2db
Host: localhost
Address: 127.0.0.1
State: UNKNOWN
Info:
● ndo2db.service - Nagios Data Out Daemon
I have narrowed it down to the binary /usr/local/nagios/bin/ndomod.o
When I execute it, I get
# /usr/local/nagios/bin/ndomod.o
Segmentation fault
I have tried compiling it myself with the result.
And here is the service status:
Loaded: loaded (/usr/lib/systemd/system/ndo2db.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Fri 2018-08-10 15:40:28 EDT; 4 days ago
Docs: http://www.nagios.org/documentation
Process: 30102 ExecStopPost=/bin/rm -f /usr/local/nagios/var/ndo2db.pid (code=exited, status=0/SUCCESS)
Process: 30099 ExecStart=/usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg -f (code=exited, status=1/FAILURE)
Main PID: 30099 (code=exited, status=1/FAILURE)
Aug 10 15:40:28 sentry systemd[1]: Started Nagios Data Out Daemon.
Aug 10 15:40:28 sentry systemd[1]: Starting Nagios Data Out Daemon...
Aug 10 15:40:28 sentry systemd[1]: ndo2db.service: main process exited, code=exited, status=1/FAILURE
Aug 10 15:40:28 sentry systemd[1]: Unit ndo2db.service entered failed state.
Aug 10 15:40:28 sentry systemd[1]: ndo2db.service failed.
Any help is appreciated! Thanks!
Re: localhost/Service Status - ndo2db is UNKNOWN
The ndomod.o binary is not meant to be ran from the command line so that is why it is erring out when you do.
I would guess that the ndo2db service is not starting because of a left over lock or sock file so lets remove them and start the daemon.
Run this as root.
rm -rf /usr/local/nagios/var/ndo.sock
rm -rf /usr/local/nagios/var/ndo2db.lock
service ndo2db start
Then check it to see if it started by running
service ndo2db status
Let us know if it started for you.
abiswas
Post by abiswas »
tgriep wrote:The ndomod.o binary is not meant to be ran from the command line so that is why it is erring out when you do.
Run this as root.
Thanks!! That worked out perfectly
Run this as root.
Great Closing thread
