_grokparsefailure_sysloginput tag
mgarrity10
Post by mgarrity10 »
I am trying to feed in a linux server from our DMZ to our local Nagios Log Server and after setting everything up with the Curl command I only get 1 log that shows up with the following message: "\xFF\xF4\xFF\xFD\u0006^]\r\n" in NLS. It has a _grokparsefailure_sysloginput tag attached to it, and I'm not sure if I need to do anything extra so that logs come into NLS normally.
Re: _grokparsefailure_sysloginput tag
By default, the syslog input only supports RFC3164 syslog messages.
If your sending server isn't sending a compliant message you will get a _grokparsefailure_sysloginput
For this, you may want to create a new tcp or udp input on a different port in the configuration and send your logs to that port
tcp {
    type => 'alt_syslog'
    port => 2099
udp {
    port => 2099
mgarrity10
Thanks for the quick response. I am actually using a DMZ relay Nagios Log Server to send all logs from DMZ clients to our local level NAgios Log Server. Could this setup be messing up the syslog format?
mgarrity10 wrote:Thanks for the quick response. I am actually using a DMZ relay Nagios Log Server to send all logs from DMZ clients to our local level NAgios Log Server. Could this setup be messing up the syslog format?
Could be, could you elaborate on this setup and configuration on both servers?
