Local Backups Not Replacing Oldest
matt.lilek
Post by matt.lilek »
Hello Team,
Seems as though even with the backup limit set to 1 they just keep on piling up. I have 2 instances that have the same issue ATT1-NAG1 and ATT3-NAG1, we also have an instance that will not backup at all ATT5-NAG1. I have deleted all backups for ATT1-NAG1 and ATT3-NAG1 just to see them pile up again and again. I have attached the profile for each. Let me know if you need anything else from my end.
Thank you!
Re: Local Backups Not Replacing Oldest
This is a know issue with a resolution posted here
https://support.nagios.com/forum/viewto ... 31#p258693
matt.lilek
Hey Scott, I see that this was a FTP backup issue, does this apply to my local backup issue as well?
matt.lilek wrote:Hey Scott, I see that this was a FTP backup issue, does this apply to my local backup issue as well?
That is correct.
I just found one post that had the fix.
matt.lilek
Ok, Thanks Scott! Ill give it a go in the morning.
matt.lilek wrote:Ok, Thanks Scott! Ill give it a go in the morning.
Sounds good.
Let us know if you run into issues.
matt.lilek
Hey Scott, I replaced the files on ATT5-NAG1 and ATT3-NAG1 and seemed to have no effect. ATT5 was not backing up and is still not backing up and ATT3 did not replace the old file. I have deleted all backups now and will wait to see if that has any effect. As for ATT5 well....... I have replace the files in ATT1 today and removed all backups to have a fresh start and will find out on Monday if it has worked or not. Looks like we might need a remote either way to get the backups working for ATT5 even if the changes do work for ATT1 and ATT5. Let me know what works for you. Thanks!
matt.lilek wrote:Hey Scott, I replaced the files on ATT5-NAG1 and ATT3-NAG1 and seemed to have no effect. ATT5 was not backing up and is still not backing up and ATT3 did not replace the old file. I have deleted all backups now and will wait to see if that has any effect. As for ATT5 well....... I have replace the files in ATT1 today and removed all backups to have a fresh start and will find out on Monday if it has worked or not. Looks like we might need a remote either way to get the backups working for ATT5 even if the changes do work for ATT1 and ATT5. Let me know what works for you. Thanks!
The changes will only be noticeable after the scheduled backups run, so once it creates a new backup it should remove the extras, all on the next scheduled backup time AFTER you made the changes.
matt.lilek
Hey Scott, I made the changes last night before i logged off and the backups should have run but they didnt, and on top of that the Backup section in the Admin Tab is totally gone. Please advise. Thank you,
Ahh, you must have accidentally changed the permissions then
run this
chown nagios.nagios /usr/local/nagiosxi/html/includes/components/scheduledbackups/scheduledbackups.inc.php
