Hi All,
There is problem with nagios sms sending. We use postgres to store sms in database and gnokii-smsd-pgsql, which is send them out. The problem is that sometimes insert good phone number, sometimes insert only a $ sign in the database outbox table.
My commands which assembles the sms message in the commands.cfg:
command_name host-notify-by-sms
command_line /usr/bin/printf "%b" "Not Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nInfo: $HOSTOUTPUT$\nIdo: $LONGDATETIME$\n\n" | /usr/local/nagios/libexec/sms2psql $CONTACTPAGER$
The sms2psql is own developed. It inserts the phone number and the whole sms message in sms database outbox table.
This is an example from my contact.cfg
define contact {
contact_name XY
alias XXXX YYYY
contactgroups NETadmins
host_notification_period 24x7
service_notification_period 24x7
host_notification_options d,r
service_notification_options w,u,c,r
host_notification_commands notify-host-by-email,host-notify-by-sms
service_notification_commands notify-service-by-email,notify-service-by-sms
email [email protected]
pager +3630XXXXXXX
When I try insert manually a sms message with sms2psql it works well. I think there is a problem in nagios and it gives wrong value in the $CONTACTPAGER$ .
Do you have any idea?
