** RESOLVED ** Nagios Core 4.4.1 - Enable HTTPS for Web GUI
amdjml
Post by amdjml »
Hi All,
I have a nagios server that runs on "http://servername/nagios/". I am using Ubuntu 18.04 LTS with Apache for the web server and I'd like to enable HTTPS for the web GUI. Here is what I have done so far:
1. Obtained a valid certificate
2. Configured Apache for SSL and enabled the default-ssl config file
When I go to "https://servername/nagios/", nothing loads. Apache & nagios logs not reporting any errors. I can see the nagios favicon on my browser but not content in the body of the browser.
There are 3 config files for apache in "/etc/apache2/sites-available/" and "/etc/apache2/sites-enabled" and they are:
000-default.conf
default-ssl.conf
nagios.conf
I have searched the web extensively and by my surprise, there aren't many articles with this topic available on the internet. Any help or guidance is greatly appreciated.
Re: Nagios Core 4.4.1 - Enable HTTPS for Web GUI
Can you share these files?
000-default.conf
default-ssl.conf
nagios.conf
amdjml
Post by amdjml »
Yes.
000-default.conf
<VirtualHost *:80>
	#ServerName www.example.com
	ServerAdmin webmaster@localhost
	DocumentRoot /var/www/html/
	ErrorLog ${APACHE_LOG_DIR}/error.log
	CustomLog ${APACHE_LOG_DIR}/access.log combined
	#RewriteEngine On
	#RewriteCond %{HTTPS} off
	#RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI}
</VirtualHost>
default-ssl.conf
<IfModule mod_ssl.c>
        <VirtualHost _default_:443>
                ServerAdmin [email protected]
                ServerName  example.com
                SSLEngine on
                SSLCertificateFile      /etc/ssl/private/certificate.crt
                SSLCertificateKeyFile /etc/ssl/private/server.key
                SSLCertificateChainFile /etc/ssl/private/chain.crt
                SSLCipherSuite EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH
                SSLProtocol All -SSLv2 -SSLv3 -TLSv1 -TLSv1.1
                SSLHonorCipherOrder On
                #Header always set Strict-Transport-Security "max-age=63072000; includeSubDomains; preload"
                Header always set Strict-Transport-Security "max-age=63072000; includeSubDomains"
                Header always set X-Frame-Options DENY
                Header always set X-Content-Type-Options nosniff
                # Requires Apache >= 2.4
                SSLCompression off
                # SSLUseStapling on
                # SSLStaplingCache "shmcb:logs/stapling-cache(150000)"
                # Requires Apache >= 2.4.11
                SSLSessionTickets Off
                SSLOpenSSLConfCmd DHParameters "/etc/ssl/private/dhparam.pem"
                BrowserMatch "MSIE [2-6]" \
                                nokeepalive ssl-unclean-shutdown \
                                downgrade-1.0 force-response-1.0
        </VirtualHost>
</IfModule>
and, nagios.conf
   SSLRequireSSL
   Options ExecCGI
   AllowOverride None
   <IfVersion >= 2.3>
      <RequireAll>
         Require all granted
#        Require host 127.0.0.1
         AuthName "Nagios Access"
         AuthType Basic
         AuthUserFile /usr/local/nagios/etc/htpasswd.users
         Require valid-user
      </RequireAll>
   </IfVersion>
   <IfVersion < 2.3>
      Order allow,deny
      Allow from all
#     Order deny,allow
#     Deny from all
#     Allow from 127.0.0.1
      AuthType Basic
      Require valid-user
   </IfVersion>
</Directory>
Alias /nagios "/usr/local/nagios/share"
<Directory "/usr/local/nagios/share">
   SSLRequireSSL
   Options None
   AllowOverride None
   <IfVersion >= 2.3>
      <RequireAll>
         Require all granted
         AuthType Basic
         Require valid-user
      </RequireAll>
   </IfVersion>
   <IfVersion < 2.3>
      Order allow,deny
      Allow from all
#     Order deny,allow
#     Deny from all
      AuthType Basic
      Require valid-user
   </IfVersion>
</Directory>
Did you restart apache after making the changes?
Also, can you send the error.log from the apache log directory.
amdjml
Post by amdjml »
I have restarted apache:
sudo systemctl restart apache2.service
There is not much in the error.log file:
[Sun Aug 19 06:25:01.739427 2018] [mpm_prefork:notice] [pid 1199] AH00163: Apache/2.4.29 (Ubuntu) OpenSSL/1.1.0g configured -- resuming normal operations
[Sun Aug 19 06:25:01.739499 2018] [core:notice] [pid 1199] AH00094: Command line: '/usr/sbin/apache2'
[Mon Aug 20 06:25:02.014935 2018] [mpm_prefork:notice] [pid 1199] AH00171: Graceful restart requested, doing restart
[Mon Aug 20 06:25:02.075393 2018] [mpm_prefork:notice] [pid 1199] AH00163: Apache/2.4.29 (Ubuntu) OpenSSL/1.1.0g configured -- resuming normal operations
[Mon Aug 20 06:25:02.075423 2018] [core:notice] [pid 1199] AH00094: Command line: '/usr/sbin/apache2'
[Mon Aug 20 11:35:51.173516 2018] [mpm_prefork:notice] [pid 1199] AH00169: caught SIGTERM, shutting down
[Mon Aug 20 11:35:51.338079 2018] [mpm_prefork:notice] [pid 23227] AH00163: Apache/2.4.29 (Ubuntu) OpenSSL/1.1.0g configured -- resuming normal operations
[Mon Aug 20 11:35:51.338155 2018] [core:notice] [pid 23227] AH00094: Command line: '/usr/sbin/apache
If you look at your access.log while trying to connect to the https URL do you see the log entry?
amdjml
Post by amdjml »
Yes, I do:
10.x.x.x - nagiosadmin [20/Aug/2018:12:12:49 -0400] "GET /nagios/ HTTP/1.1" 200 5794 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/68.0.3440.106 Safari/537.36"
10.x.x.x - nagiosadmin [20/Aug/2018:12:12:49 -0400] "GET /nagios/side.php HTTP/1.1" 200 1555 "https://example.com/nagios/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/68.0.3440.106 Safari/537.36"
10.x.x.x - nagiosadmin [20/Aug/2018:12:12:49 -0400] "GET /nagios/main.php HTTP/1.1" 200 3500 "https://example.com/nagios/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/68.0.3440.106 Safari/537.36"
10.x.x.x - nagiosadmin [20/Aug/2018:12:12:50 -0400] "GET /nagios/images/favicon.ico HTTP/1.1" 200 1270 "https://example.com/nagios/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/68.0.3440.106 Safari/537.36"
... and this is what I see on my browser:
amdjml
Post by amdjml »
I found the solution. I am going to put what I did to resolve this.
In Chrome, I opened the "Inspect" tool and clicked on the "Console" tab and I saw the message below:
Refused to display 'https://example.com/nagios/main.php' in a frame because it set 'X-Frame-Options' to 'deny'.
I then, edited the "default-ssl.conf" file for Apache. The line that needs to be changed (in my case) is:
Change it to:
Header always set X-Frame-Options SAMEORIGIN
Restart apache and you are done :D
/etc/init.d/apache2 restart
Great! closing
