Hello, My installation is v 5.5.2, 64-bit, VM, CentOS7, server name Winston.doit.wisc.edu
I have a server FQDN = cordelia.doit.wisc.edu , when you run the command "hostname" on the server, it says cordelia.doit.wisc.edu
I have configured the host on Winston, with "Host Name" cordelia.doit.wisc.edu, "Alias" blank, "Address" cordelia.doit.wisc.edu , it has some non-SNMP services.
I send a SNMP trap from Cordelia.doit.wisc.edu to Winston.doit.wisc.edu
In the "Unconfigured Objects" list, it lists "cordelia", not "cordelia.doit.wisc.edu"
If I configure the "Unconfigured Object" it will create a host "cordelia" and the service for the trap, which does passively accept and display SNMP traps sent from Cordelia.doit.wisc.edu
How to I get the Unconfigured Object to configure for the existing host cordelia.doit.wisc.edu ? When I configure it, I see a window with the "cordelia" name in it, but I cannot edit the name.
Earl
SNMP unconfigured objects problem
Re: SNMP unconfigured objects problem
There is not currently a way to remap it, XI is just showing you what it received and they need to match.
More than likely it's stripping the domain because of a setting in your /etc/snmp/snmptt.ini file:
If you make a change, make sure to restart the snmptt service:
That should send the FQDN then.
Thank you
# Set to 0 to enable the use of FQDN (Fully Qualified Domain Names). If a host name is
# passed to SNMPTT that contains a domain name, it will not be altered in any way by
# SNMPTT. This also affects resolve_value_ip_addresses.
# Set to 1 to have SNMPTT strip the domain name from the host name passed to it. For
# example, server01.domain.com would be changed to server01
# Set to 2 to have SNMPTT strip the domain name from the host name passed to it
# based on the list of domains in strip_domain_list
strip_domain = 1Code: Select all
service snmptt restartThank you
Bitflogger
That worked.
Thanks!
Please lock it.
Earl
Thanks!
Please lock it.
Earl
