We tried to upgrade Nagios the other day and the upgrade hasn't worked, it is still running 5.2.9.
__:: xiversion ::__
nagios@smpnagios-kn-t100 init.d]$ cat /usr/local/nagiosxi/var/xiversion
# DO NOT DELETE THIS FILE!
# Nagios XI version information
full=5.2.9
major=5
minor=2.9
releasedate=2016-06-14
release=520
__:: Nagiosxi md5sum ::__
[nagios@smpnagios-kn-t100 rpms]$ md5sum nagiosxi-5.5.2-1.el6.x86_64.tar.gz
13030e22fcfe9f88eabc9bcef7bcbf24 nagiosxi-5.5.2-1.el6.x86_64.tar.gz
__:: Install output ::__
Followed the following instructions:
scp nagiosxi-5.5.2-1.el6.x86_64.tar.gz smpnagios-kn-t100:/tmp
rm -r /tmp/rpms/nagios*
mkdir -p /tmp/rpms
mv /tmp/nagiosxi* /tmp/rpms
cd /tmp/rpms
tar xzf nagiosxi*
cd nagiosxi
./upgrade
__:: Output of the upgrade command ::__
Return-Code : Success
Loaded plugins: enabled_repos_upload, package_upload, product-id, search-
: disabled-repos, security, subscription-manager
Transaction ID : 31
Begin time : Tue Aug 21 12:29:50 2018
Begin rpmdb : 766:25283703c6f3fdb1f9646d36d5c1e84444eaa67d
End time : 12:30:34 2018 (44 seconds)
End rpmdb : 775:eb29a5a97eba8cafdb8f816639d9ebfead4e464b
User : Alan WOLFFS, Unix TS <w7595593>
Command Line : -y --nogpgcheck localinstall fping-3.10-1.el6.rf.x86_64.rpm freetds-0.91-2.el6.x86_64.rpm libmcrypt-2.5.8-9.el6.x86_64.rpm nagiosxi-5.5.2-1.el6.x86_64.rpm nagiosxi-mrtg-5.5.
2-1.el6.x86_64.rpm nagiosxi-nagioscore-5.5.2-1.el6.x86_64.rpm nagiosxi-nagiosmobile-5.5.2-1.el6.x86_64.rpm nagiosxi-nagiosplugins-5.5.2-1.el6.x86_64.rpm nagiosxi-nagvis-5.5.2-1.el6.x86_64.rp
m nagiosxi-ndoutils-5.5.2-1.el6.x86_64.rpm nagiosxi-nrds-5.5.2-1.el6.x86_64.rpm nagiosxi-nrpe-5.5.2-1.el6.x86_64.rpm nagiosxi-nsca-5.5.2-1.el6.x86_64.rpm nagiosxi-nxti-5.5.2-1.el6.x86_64.rpm
nagiosxi-pnp-5.5.2-1.el6.x86_64.rpm nagiosxi-shellinabox-5.5.2-1.el6.x86_64.rpm nagiosxi-wkhtmltox-5.5.2-1.el6.x86_64.rpm nagiosxi-wmic-5.5.2-1.el6.x86_64.rpm nmap-6.47-1.x86_64.rpm perl-Co
nfig-IniFiles-2.72-2.el6.noarch.rpm perl-Crypt-DES-2.05-9.el6.x86_64.rpm perl-Crypt-Rijndael-1.09-2.el6.x86_64.rpm perl-Mail-IMAPClient-3.37-1.el6.noarch.rpm perl-Mail-POP3Client-2.18-6.el6.
noarch.rpm perl-Math-Calc-Units-1.07-6.el6.noarch.rpm perl-Nagios-Monitoring-Plugin-0.51-1.el6.noarch.rpm perl-Net-SMTP-TLS-0.12-1.el6.rf.noarch.rpm perl-Net-SNMP-5.2.0-4.el6.noarch.rpm perl
-Number-Format-1.73-3.el6.noarch.rpm php-mcrypt-5.3.3-5.el6.x86_64.rpm php-mssql-5.3.3-5.el6.x86_64.rpm php-pear-HTML-Template-IT-1.3.0-2.el5.noarch.rpm php-pecl-ssh2-0.11.0-7.el6.x86_64.rpm
pymssql-1.0.2-4.el6.x86_64.rpm python-bson-2.5.2-3.el6.1.x86_64.rpm python-pymongo-2.5.2-3.el6.1.x86_64.rpm
Transaction performed with:
Installed rpm-4.8.0-55.el6.x86_64 @rhel-x86_64-server-6
Installed subscription-manager-1.18.10-1.el6.x86_64 @rhel-x86_64-server-6
Installed yum-3.2.29-81.el6.noarch @rhel-x86_64-server-6
Installed yum-metadata-parser-1.1.2-16.el6.x86_64 @anaconda-RedHatEnterpriseLinux-201409260744.x86_64/6.6
Packages Altered:
Dep-Install autoconf-2.63-5.1.el6.noarch @rhel-6-server-rpms
Dep-Install automake-1.11.1-4.el6.noarch @rhel-6-server-rpms
Updated nagiosxi-5-2.9.el6.x86_64 @/nagiosxi-5-2.9.el6.x86_64
Update 5.5.2-1.el6.x86_64 @/nagiosxi-5.5.2-1.el6.x86_64
Updated nagiosxi-mrtg-5-2.9.el6.x86_64 @/nagiosxi-mrtg-5-2.9.el6.x86_64
Update 5.5.2-1.el6.x86_64 @/nagiosxi-mrtg-5.5.2-1.el6.x86_64
Updated nagiosxi-nagioscore-5-2.9.el6.x86_64 @/nagiosxi-nagioscore-5-2.9.el6.x86_64
Update 5.5.2-1.el6.x86_64 @/nagiosxi-nagioscore-5.5.2-1.el6.x86_64
Updated nagiosxi-nagiosmobile-5-2.9.el6.x86_64 @/nagiosxi-nagiosmobile-5-2.9.el6.x86_64
Update 5.5.2-1.el6.x86_64 @/nagiosxi-nagiosmobile-5.5.2-1.el6.x86_64
Updated nagiosxi-nagiosplugins-5-2.9.el6.x86_64 @/nagiosxi-nagiosplugins-5-2.9.el6.x86_64
Update 5.5.2-1.el6.x86_64 @/nagiosxi-nagiosplugins-5.5.2-1.el6.x86_64
Updated nagiosxi-nagvis-5-2.9.el6.x86_64 @/nagiosxi-nagvis-5-2.9.el6.x86_64
Update 5.5.2-1.el6.x86_64 @/nagiosxi-nagvis-5.5.2-1.el6.x86_64
Updated nagiosxi-ndoutils-5-2.9.el6.x86_64 @/nagiosxi-ndoutils-5-2.9.el6.x86_64
Update 5.5.2-1.el6.x86_64 @/nagiosxi-ndoutils-5.5.2-1.el6.x86_64
Updated nagiosxi-nrds-5-2.9.el6.x86_64 @/nagiosxi-nrds-5-2.9.el6.x86_64
Update 5.5.2-1.el6.x86_64 @/nagiosxi-nrds-5.5.2-1.el6.x86_64
Updated nagiosxi-nrpe-5-2.9.el6.x86_64 @/nagiosxi-nrpe-5-2.9.el6.x86_64
Update 5.5.2-1.el6.x86_64 @/nagiosxi-nrpe-5.5.2-1.el6.x86_64
Updated nagiosxi-nsca-5-2.9.el6.x86_64 @/nagiosxi-nsca-5-2.9.el6.x86_64
Update 5.5.2-1.el6.x86_64 @/nagiosxi-nsca-5.5.2-1.el6.x86_64
Install nagiosxi-nxti-5.5.2-1.el6.x86_64 @/nagiosxi-nxti-5.5.2-1.el6.x86_64
Updated nagiosxi-pnp-5-2.9.el6.x86_64 @/nagiosxi-pnp-5-2.9.el6.x86_64
Update 5.5.2-1.el6.x86_64 @/nagiosxi-pnp-5.5.2-1.el6.x86_64
Install nagiosxi-shellinabox-5.5.2-1.el6.x86_64 @/nagiosxi-shellinabox-5.5.2-1.el6.x86_64
Updated nagiosxi-wkhtmltox-5-2.9.el6.x86_64 @/nagiosxi-wkhtmltox-5-2.9.el6.x86_64
Update 5.5.2-1.el6.x86_64 @/nagiosxi-wkhtmltox-5.5.2-1.el6.x86_64
Updated nagiosxi-wmic-5-2.9.el6.x86_64 @/nagiosxi-wmic-5-2.9.el6.x86_64
Update 5.5.2-1.el6.x86_64 @/nagiosxi-wmic-5.5.2-1.el6.x86_64
Dep-Install net-snmp-perl-1:5.5-60.el6.x86_64 @rhel-6-server-rpms
Dep-Install perl-Config-Tiny-2.12-7.1.el6.noarch @rhel-6-server-optional-rpms
Install perl-Math-Calc-Units-1.07-6.el6.noarch @/perl-Math-Calc-Units-1.07-6.el6.noarch
Install perl-Nagios-Monitoring-Plugin-0.51-1.el6.noarch @/perl-Nagios-Monitoring-Plugin-0.51-1.el6.noarch
Dep-Install php-devel-5.3.3-49.el6.x86_64 @rhel-6-server-optional-rpms
Updated php-mcrypt-5.3.3-4.el6.x86_64 @/php-mcrypt-5.3.3-4.el6.x86_64
Update 5.3.3-5.el6.x86_64 @/php-mcrypt-5.3.3-5.el6.x86_64
Updated php-mssql-5.3.3-4.el6.x86_64 @/php-mssql-5.3.3-4.el6.x86_64
Update 5.3.3-5.el6.x86_64 @/php-mssql-5.3.3-5.el6.x86_64
Scriptlet output:
Since performing the upgrade I cannot start Nagios either, it's asking me a password even though I have sudo access to the nagios user.
/etc/init.d/nagios start
Starting nagios: Password:
[nagios@smpnagios-kn-t100 ~]$ /etc/init.d/nagios status
/etc/init.d/nagios: line 164: head: command not found
nagios is not running
Could someone assist please? I can't access the customer forum yet.
Upgrade from 5.2.9 to 5.5.2 failed
Re: Upgrade from 5.2.9 to 5.5.2 failed
switch user to root
Then run the following
Then try running
rm -f /usr/local/nagiosxi/html/includes/components/nrdsconfigmanager/install.sh
rm -f /usr/local/nagiosxi/html/includes/components/nagvis/install.sh
rm -f /usr/local/nagiosxi/html/includes/components/snmptrapsender/install.sh
rm -f /usr/local/nagiosxi/html/includes/configwizards/windowswmi/install.sh
rm -f /usr/local/nagiosxi/html/includes/configwizards/domain_expiration/install.sh
rm -f /usr/local/nagiosxi/html/includes/configwizards/ftpserver/install.sh
rm -f /usr/local/nagiosxi/html/includes/configwizards/exchange/install.sh
rm -f /usr/local/nagiosxi/html/includes/configwizards/mailserver/install.sh
rm -f /usr/local/nagiosxi/html/includes/configwizards/mongodb_database/install.sh
rm -f /usr/local/nagiosxi/html/includes/configwizards/mongodb_server/install.sh
rm -f /usr/local/nagiosxi/html/includes/configwizards/folder_watch/install.sh
yum-complete-transactionRe: Upgrade from 5.2.9 to 5.5.2 failed
It looks like there are no outstanding transactions to complete, is it OK to run this?
Regards,
Paul
Regards,
Paul
We tried the above
root@smpnagios-kn-t100 # rm -f /usr/local/nagiosxi/html/includes/components/nrdsconfigmanager/install.sh
root@smpnagios-kn-t100 # rm -f /usr/local/nagiosxi/html/includes/components/nagvis/install.sh
root@smpnagios-kn-t100 # rm -f /usr/local/nagiosxi/html/includes/components/snmptrapsender/install.sh
root@smpnagios-kn-t100 # rm -f /usr/local/nagiosxi/html/includes/configwizards/windowswmi/install.sh
root@smpnagios-kn-t100 # rm -f /usr/local/nagiosxi/html/includes/configwizards/domain_expiration/install.sh
root@smpnagios-kn-t100 # rm -f /usr/local/nagiosxi/html/includes/configwizards/ftpserver/install.sh
root@smpnagios-kn-t100 # rm -f /usr/local/nagiosxi/html/includes/configwizards/exchange/install.sh
root@smpnagios-kn-t100 # rm -f /usr/local/nagiosxi/html/includes/configwizards/mailserver/install.sh
root@smpnagios-kn-t100 # rm -f /usr/local/nagiosxi/html/includes/configwizards/mongodb_database/install.sh
root@smpnagios-kn-t100 # rm -f /usr/local/nagiosxi/html/includes/configwizards/mongodb_server/install.sh
root@smpnagios-kn-t100 # rm -f /usr/local/nagiosxi/html/includes/configwizards/folder_watch/install.sh
root@smpnagios-kn-t100 # yum-complete-transaction
Loaded plugins: product-id, subscription-manager
rhel-6-server-optional-rpms | 2.0 kB 00:00
rhel-6-server-rpms | 2.0 kB 00:00
rhel-6-server-satellite-tools-6.2-rpms | 2.1 kB 00:00
No unfinished transactions left.
and this is what we got.
yum reinstall -y ./fping-3.10-1.el6.rf.x86_64.rpm
yum reinstall -y ./freetds-0.91-2.el6.x86_64.rpm
yum reinstall -y ./perl-Net-SMTP-TLS-0.12-1.el6.rf.noarch.rpm
yum reinstall -y ./perl-Math-Calc-Units-1.07-6.el6.noarch.rpm
yum reinstall -y ./perl-Mail-POP3Client-2.18-6.el6.noarch.rpm
yum reinstall -y ./python-pymongo-2.5.2-3.el6.1.x86_64.rpm
yum reinstall -y ./perl-Mail-IMAPClient-3.37-1.el6.noarch.rpm
yum reinstall -y ./python-bson-2.5.2-3.el6.1.x86_64.rpm
yum reinstall -y ./perl-Crypt-Rijndael-1.09-2.el6.x86_64.rpm
yum reinstall -y ./php-mssql-5.3.3-5.el6.x86_64.rpm
yum reinstall -y ./nmap-6.47-1.x86_64.rpm
yum reinstall -y ./perl-Config-IniFiles-2.72-2.el6.noarch.rpm
yum reinstall -y ./php-mcrypt-5.3.3-5.el6.x86_64.rpm
yum reinstall -y ./perl-Number-Format-1.73-3.el6.noarch.rpm
yum reinstall -y ./libmcrypt-2.5.8-9.el6.x86_64.rpm
yum reinstall -y ./perl-Net-SNMP-5.2.0-4.el6.noarch.rpm
yum reinstall -y ./perl-Crypt-DES-2.05-9.el6.x86_64.rpm
yum reinstall -y ./pymssql-1.0.2-4.el6.x86_64.rpm
yum reinstall -y ./php-pear-HTML-Template-IT-1.3.0-2.el5.noarch.rpm
yum reinstall -y ./php-pecl-ssh2-0.11.0-7.el6.x86_64.rpm
yum reinstall -y ./perl-Nagios-Monitoring-Plugin-0.51-1.el6.noarch.rpm
yum reinstall -y ./nagiosxi-nsca-5.5.2-1.el6.x86_64.rpm ./nagiosxi-nxti-5.5.2-1.el6.x86_64.rpm ./nagiosxi-pnp-5.5.2-1.el6.x86_64.rpm ./nagiosxi-shellinabox-5.5.2-1.el6.x86_64.rpm ./nagiosxi-5.5.2-1.el6.x86_64.rpm ./nagiosxi-wkhtmltox-5.5.2-1.el6.x86_64.rpm ./nagiosxi-mrtg-5.5.2-1.el6.x86_64.rpm ./nagiosxi-wmic-5.5.2-1.el6.x86_64.rpm ./nagiosxi-nagioscore-5.5.2-1.el6.x86_64.rpm ./nagiosxi-nagiosmobile-5.5.2-1.el6.x86_64.rpm ./nagiosxi-nagiosplugins-5.5.2-1.el6.x86_64.rpm ./nagiosxi-nagvis-5.5.2-1.el6.x86_64.rpm ./nagiosxi-ndoutils-5.5.2-1.el6.x86_64.rpm ./nagiosxi-nrds-5.5.2-1.el6.x86_64.rpm ./nagiosxi-nrpe-5.5.2-1.el6.x86_64.rpm
Regards,
Paul
We tried the above
Regards,
Paul
Did you run these?ppalmer wrote:Code: Select all
yum reinstall -y ./fping-3.10-1.el6.rf.x86_64.rpm yum reinstall -y ./freetds-0.91-2.el6.x86_64.rpm yum reinstall -y ./perl-Net-SMTP-TLS-0.12-1.el6.rf.noarch.rpm yum reinstall -y ./perl-Math-Calc-Units-1.07-6.el6.noarch.rpm yum reinstall -y ./perl-Mail-POP3Client-2.18-6.el6.noarch.rpm yum reinstall -y ./python-pymongo-2.5.2-3.el6.1.x86_64.rpm yum reinstall -y ./perl-Mail-IMAPClient-3.37-1.el6.noarch.rpm yum reinstall -y ./python-bson-2.5.2-3.el6.1.x86_64.rpm yum reinstall -y ./perl-Crypt-Rijndael-1.09-2.el6.x86_64.rpm yum reinstall -y ./php-mssql-5.3.3-5.el6.x86_64.rpm yum reinstall -y ./nmap-6.47-1.x86_64.rpm yum reinstall -y ./perl-Config-IniFiles-2.72-2.el6.noarch.rpm yum reinstall -y ./php-mcrypt-5.3.3-5.el6.x86_64.rpm yum reinstall -y ./perl-Number-Format-1.73-3.el6.noarch.rpm yum reinstall -y ./libmcrypt-2.5.8-9.el6.x86_64.rpm yum reinstall -y ./perl-Net-SNMP-5.2.0-4.el6.noarch.rpm yum reinstall -y ./perl-Crypt-DES-2.05-9.el6.x86_64.rpm yum reinstall -y ./pymssql-1.0.2-4.el6.x86_64.rpm yum reinstall -y ./php-pear-HTML-Template-IT-1.3.0-2.el5.noarch.rpm yum reinstall -y ./php-pecl-ssh2-0.11.0-7.el6.x86_64.rpm yum reinstall -y ./perl-Nagios-Monitoring-Plugin-0.51-1.el6.noarch.rpm yum reinstall -y ./nagiosxi-nsca-5.5.2-1.el6.x86_64.rpm ./nagiosxi-nxti-5.5.2-1.el6.x86_64.rpm ./nagiosxi-pnp-5.5.2-1.el6.x86_64.rpm ./nagiosxi-shellinabox-5.5.2-1.el6.x86_64.rpm ./nagiosxi-5.5.2-1.el6.x86_64.rpm ./nagiosxi-wkhtmltox-5.5.2-1.el6.x86_64.rpm ./nagiosxi-mrtg-5.5.2-1.el6.x86_64.rpm ./nagiosxi-wmic-5.5.2-1.el6.x86_64.rpm ./nagiosxi-nagioscore-5.5.2-1.el6.x86_64.rpm ./nagiosxi-nagiosmobile-5.5.2-1.el6.x86_64.rpm ./nagiosxi-nagiosplugins-5.5.2-1.el6.x86_64.rpm ./nagiosxi-nagvis-5.5.2-1.el6.x86_64.rpm ./nagiosxi-ndoutils-5.5.2-1.el6.x86_64.rpm ./nagiosxi-nrds-5.5.2-1.el6.x86_64.rpm ./nagiosxi-nrpe-5.5.2-1.el6.x86_64.rpm cat /usr/local/nagiosxi/var/xiversion
