We are using a cert checker plugin on various RHEL hosts. I have a discrepancy between my configurations on RHEL{6,7} hosts and I cannot figure out why.
nagios-server:
[jenglish@boy-adams ~]$ /usr/lib/nagios/plugins/check_nrpe -H ftm-opdevods01 -c check_java_keystore -t 1000 -a /opt/app/ods-np2/keystore/ssl.keystore JCEKS "oIw1d90caP" 90 45
NRPE: Unable to read outputCode: Select all
(DEV-FM|jenglish@ftm-opdevods01 ~)$ sudo grep 'nagios\|nrpe' /etc/sudoers | grep -v '^#'
nagios ALL=NOPASSWD:!ALL, /sbin/multipath -ll, /sbin/service iptables status, /usr/sbin/hpacucli, /usr/sbin/dmidecode, /bin/egrep, /usr/sbin/ethtool -S *, /sbin/service * restart, /usr/lib/nagios/plugins/check_java_keystore
Aug 23 10:25:57 ftm-opdevods01 sudo: nrpe : user NOT in sudoers ; TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/lib/nagios/plugins/check_java_keystore --keystore /opt/app/ods-np2/keystore/ssl.keystore --storetype JCEKS --password oIw1d90caP -w 90 -c 45So if I run the same NRPE command from the nagios-server against a RHEL6 host I get this ...
(DEV-FTM|jenglish@ftm-opdevapp08 ~)$ sudo grep 'nagios\|nrpe' /etc/sudoers | grep -v '^#'
Aug 23 10:27:54 ftm-opdevapp08 sudo: nagios : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/lib/nagios/plugins/check_java_keystore --keystore /opt/share/sv1/TOBE/alf_data/keystore/ssl.truststore --storetype JCEKS --password oIw1d90caP -w 90 -c 45Thanks!
