Hello:
I upgraded to 5.5.2 last night and I am seeing an issue where I can't set downtimes. I have attached some screenshots. Thanks!
Can't set downtimes after upgrade
Re: Can't set downtimes after upgrade
This can be closed off, it was resolved trying to fix a different issue. Thanks!
npolovenko
- Support Tech
@CameronWP, Please run the following commands and show me the output:
getenforce
service nagios status
ls -l /usr/local/nagios/var/rw
Also, this will check your configuration files for errors:grep nag /etc/group
