Dear Support,
Is there any issue/supported if we were to install NagiosXI on a separate partition? We create separate mount point for /usr/local/.
The purpose is to separate /usr/local/ from / directory. Kindly advise.
OS: Redhat 7.4
NagiosXI version: 5.4.13
Regards,
Faiz
Create separate partition for NagiosXI installation
astiostech18
Re: Create separate partition for NagiosXI installation
Technically you shouldn't have any problems if it's mounted to the proper location and the permissions are correct.
