exclude function and the static directory
Bitflogger
Post by Bitflogger »
Hello, I am running v5.5.2, 64-bit, VM, CentOS7
I have set up some files in the static directory, due to the need to exclude some hostgroups in some service definitions.
I see a !<checkbox> in the Manage Hostgroups widget, for each included hostgroup, so is the static directory still required for the exclude syntax?
Earl
Re: exclude function and the static directory
Bitflogger wrote:I see a !<checkbox> in the Manage Hostgroups widget, for each included hostgroup, so is the static directory still required for the exclude syntax?
No it is not, you can now create hostgroups the exclude hosts in the CCM using the ! <checkbox> you found
Bitflogger
Thanks! Please lock it.
Earl
Bitflogger wrote:Thanks! Please lock it.
Earl
Locking
