NagiosXI upgrade fails from GUI and command prompt
thanigaivel.a
Post by thanigaivel.a »
NagiosXI upgrade fails from GUI and as well as command prompt.
profile attached.
Re: NagiosXI upgrade fails from GUI and command prompt
Can you post the upgrade.log file from the upgrade directory when you tried from the command line?
thanigaivel.a
Yes, its a space issue, after increasing the disk space, now upgraded successfully. thank you
thanigaivel.a wrote:Yes, its a space issue, after increasing the disk space, now upgraded successfully. thank you
Great! glad it is resolved
Locking thread
