Nagios sudoers.d
hbouma
Nagios sudoers.d
Post by hbouma »
I know that nagios makes changes to the sudoers file. Is there a way to move them out of /etc/sudoers into a file under /etc/sudoers.d file?
We do not allow modification of the /etc/sudoers file directly and require that all changes be placed in /etc/sudoers.d.
Re: Nagios sudoers.d
You can make this move and it should work correctly, however you will need to make the changes on every upgrade.
hbouma
Post by hbouma »
Thank you. That is all I needed.
hbouma wrote:Thank you. That is all I needed.
Locking thread
