CHECK_NRPE STATE CRITICAL: Socket timeout after 10 seconds.
taxiarxos
Post by taxiarxos »
I am having an issue while I try to connect a windows server 2016 with an Icinga2 ubuntu 18 monitoring server. The outputs are below:
root@nms:~# sudo /usr/lib/nagios/plugins/check_nrpe -H 10.10.0.100 -n
I (0.5.2.35 2018-01-28) seem to be doing fine...
root@nms:~# sudo /usr/lib/nagios/plugins/check_nrpe -H 10.10.0.100 -p 5666 -c CheckMEM -a MaxWarn=80 MaxCrit=90 ShowAll type=physical
This is the .ini file on client
; in flight - TODO
[/settings/default]
; Undocumented key
password = XXXXXXXXX
; Undocumented key
allowed hosts = 10.10.0.110
[/settings/NRPE/server]
insecure = true
allow arguments = 1
allow nasty_meta chars = 1
port = 5666
use SSL = 0
ssl options =
verify mode = none
insecure = true
cache allowed hosts = false
ssl options =
allow arguments = true
allow nasty characters = true
timeout=60
host_check_timeout=30
service_check_timeout=60
; in flight - TODO
[/modules]
; Undocumented key
CheckExternalScripts = disabled
; Undocumented key
CheckHelpers = disabled
; Undocumented key
CheckEventLog = disabled
; Undocumented key
CheckNSCP = disabled
; Undocumented key
CheckDisk = disabled
; Undocumented key
CheckSystem = disabled
; Undocumented key
NRPEServer = enabled
; Undocumented key
NSClientServer = enabled
;# SOCKET TIMEOUT
; Timeout when reading packets on incoming sockets. If the data has not arrived withint this time we will bail out.
socket_timeout=60
Re: CHECK_NRPE STATE CRITICAL: Socket timeout after 10 secon
Sorry, we cannot support Icinga2
