Help with NPRE
jagannathan
Help with NPRE
Post by jagannathan »
Moderator note:
This topic was split from https://support.nagios.com/forum/viewto ... 35&t=49900 as it is a different topic
Hello Folks ,
-> I need some support on plugin side using nagios plugin 2.2.1 , configured nrpe in manager machine under /usr/local/nagios/libexec directive in terminal ./check_nrpe -H ip_address passing time i am facing issue on manager side CHECK_NRPE: Error - Could not connect to ip_address: Connection reset by peer.
Re: Help with NPRE
Is NRPE running on ip_address?
In the nrep.cfg on ip_address is the nagios server's ip address in the allowed_hosts field
If not you will need to add it and restart nrpe
